Future TOTM Winner
Big Block Brackets and A/C?
Does anyone have a nice pic of what the stock A/C compressor setup should look like on my 78 454? I'm familiar with small blocks but this is my first big boy and I'm feeling a little lost for knowledge.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
Future TOTM Winner
Re: Big Block Brackets and A/C?
Nobody has a Big Block with A/C?
Just Another Crazy Canuck
just roll down the windows and pin it !!
that's my ac setup on my big block, which happens to also be a 78 454 ![]()
1985 ![]() ![]() ![]() soon to be installed: 14bDETROIT,Edelbrock Performer cam,intake and valve springs,Comp roller tips,MSD HEI |
#4 | |
Future TOTM Winner
Future TOTM Winner
riiiight...the truck is worth about $500
I also would like to see a pic, I'm guessing my '79 should be the same.
BMW & ASE Master Certified
if you have v-belts you could start over with a set of serpentine belt brackets off of a 88-92 sbc camaro/trans am.. requires a little bit of modding, some 3/8 aluminum plate and your set. I did that on my 87 and used f-body a/c hoses, everything for the a/c was factory 87.
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
^Caprice brackets can also be used, they are the same.
-Andy '77 K5 Blazer '78 K10 Shortbed '78 C20 Suburban '79 K30 Crew Cab Dually '84 C10 Short Stepside '88 K20 Suburban ![]() |
Future TOTM Winner
Thanks guys, I don't think I am wanting to get that involved with it at the moment. The truck is (at the moment) just an old beater but I plan to drive it quite a bit for work purposes. I might just go get a v-belt Sanden compressor and make my own brackets. Here are a couple pics of the brackets that are currently there. I know I am missing a couple parts, but I haven't figured out exactly what...yet.
This is of my 89 crew cab dually.
Navy Radioman Veteran
Hopefully, this will help you out a bit.
It's from a '76 3/4ton where I pulled the motor out and re-worked it for my '87. I used the big pictures so you could blow them up and get good detail. Good Luck. Kenny
1987 Chevrolet R10 Silverado BBC Build thread - SOLD 1986 GMC Sierra Classic - SOLD 1957 Chevy Step Side - At the Body Shop Daily Driver; 2005 Chevrolet Silverado 4x4 Z71 Stepside |
Future TOTM Winner
Thanks Lowrider, that's exactly what I needed!
