Old 04-19-2010, 09:34 PM   #101
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Re: Thanks for asking.....here is project: Patina'd
LOL.....everytime I see your avitar it reminds me of "meatloaf". How crazy it that?
Wont be long and I'm gunna drag that turn out of storage. Going to get the build thread a little more up to date. I didn't even realize it doesn't reflect the tunnel ram addition. Also want to get some vids on here. Peace!
prostreetC-10 is offline   Reply With Quote
Old 04-19-2010, 11:02 PM   #102
highperf4x4
Right on man! I'll be looking for lots of pics!
highperf4x4 is offline   Reply With Quote
Old 11-14-2010, 01:22 AM   #103
nasqar
Here kitty kitty kitty
And how did things go this summer with the truck?
nasqar is offline   Reply With Quote
Old 12-03-2010, 10:42 PM   #104
Hart_Rod
Hart_Rod's Avatar
Inquiring minds want to know..../
Hart_Rod is offline   Reply With Quote
Old 12-08-2010, 12:14 PM   #105
ozman3803
Yeah any updates?
ozman3803 is offline   Reply With Quote
Old 12-21-2010, 11:53 PM   #106
prostreetC-10
My Carbon Footprint
Man.....I really suck at this whole build thread thing. I now realize that where my truck is now and where I left off on this thread are 2 different places. My last post was back in March and I said I was going to update the build thread but never got around to it. Well.......here goes! Just look down!
Old 12-22-2010, 12:03 AM   #107
prostreetC-10
My Carbon Footprint
After getting those really wide tires on the back, I knew I just had to complete the "prostreet" look. For me, that meant sumpin hangin how da hood. I didn't want to drop the coin on a real blower since is looks like I might be running some BOOST through the fastback. Next best thing would be a tunnel ram (also some old Hilborn fuel injection ram tubes would be ultra cool but darn near the cost of a blower). You know you have a great wife when she can walk past this 100 times and not ask what it is and how much it cost!!
Old 12-22-2010, 12:39 AM   #108
spike38
spike38's Avatar
Looks like a great eye catching touch!!!
And she sounds like a keeper
Spike
spike38 is offline   Reply With Quote
Old 12-22-2010, 02:34 AM   #109
prostreetC-10
My Carbon Footprint
I picked up the tunnel ram at a swap meet for $100 in great condition so I was on my way. It's a Wieand "hi-ram" for oval port heads. Has the carb bolt pattern to mount the carbs either inline or sideways.
Now on to the carbs. I was to try and cover a few things to hopefully help others out that might be thinking of a 2x4 setup. Some of the initial choices where a pair of 390's, 450's and 600's. After talking to Holley tech, I decided to go with the Holley list 9776 450 "tunnel ram" mechanical secondary carbs. Notice I said "mechanical secondary" and not "double pumper"? The 9776 is a very unique carb because it is the only carb in Holley's lineup that has a mechanical secondary but no rear accel pump thus not making it a DP. I called Holley and asked how they could get away with this because basic carb logic would tell you that you should have a nice lean spot in the secondary transition once the rear butterflies open and before the signal gets to the booster and they can have time to react. Holley claimed that the venturi is so small, and the booster is positioned just close enough to it that you will get an instant signal (I would later find out that this is not the case in my setup.....but I'll cover that a little later).
So I had the carb....now what? Do I take the easy route and mount them inline like most every other guy out there or do I complicate things by mounting them sideway. Of course.....let's complicate things and make them look bad ass at the same time. The one problem I saw right off the bat was that when sideways, the carbs hang farther over to one side than the other because the 450s only have a front block and not rear. Easy fix though. I just removed the rear metering PLATE and put on a couple of rear block conversion kits. Now she's setting dead center. Only problem left is it looks like two little carbs on a great big engine. What to do. I know....what's the baddest fuel bowl Holley makes? That's right DOMINATOR racing bowls. What's cool about Holley carbs is that just about any bowl will fit on any carb. You can take a pair of 450 carbs and make them look like 850+ carb by adding the right bowl. All the main bodies on the outside are the same shape. The CFM is controlled by how big or how small the venturis are on the inside (along with throttle bore diameter).
I knew that in order to have to carbs setting sideways and not have a real "heavy" pedal, I needed to go with quality linkage. I think the best out there is Enderle blower linkage, and that's what I got. All kinds of adjustments to really fine tune the to. It is very important to have the carbs 100% sync'd together so they act like one, or as close to it. This linkage allows you to do that. After getting the carbs on and the linkage mocked up, you have the look in the pic below. As complex as the linkage looks, it's amazing how smooth the pedal is. It has less pressure than many single carb pedals I've felt. More later......
Old 12-22-2010, 04:53 AM   #110
BC Toy chest
BC Toy chest's Avatar
Keep up the gr8 work, looking forward to seeing more.
I'm not tail-gating, I'm drafting.
http://67-72chevytrucks.com/vboard/s...d.php?t=432758
BC Toy chest is offline   Reply With Quote
Old 12-22-2010, 01:44 PM   #111
67cheby
67cheby
67cheby's Avatar
wow....thats some cool crazy stuff there !!!
67cheby is offline   Reply With Quote
Old 12-22-2010, 02:04 PM   #112
prostreetC-10
My Carbon Footprint
naw....your truck in da weeds is crazy!
Old 12-22-2010, 02:23 PM   #113
67cheby
67cheby
67cheby's Avatar
Lol....
Old 12-29-2010, 01:13 AM   #114
prostreetC-10
My Carbon Footprint
I couldn't seem to find this pic but I came across it while in my photobucket account. This is a very crude and extremely accurate way of finding out how far the carbs and scoop were going to stick out of my hood. Once I got the height of the rope, I just closed the hood and put the rope back up. The rope was attached to my fence and my back porch support. I can't remember if it was the top of the tunnel ram or the top of the carbs. Either way it put a HUGE smile on my face!!!! Come to think about it....the end of the tape measure was the top of the scoop.
Old 12-31-2010, 01:21 PM   #115
legendary
legendary's Avatar
Awesome work....subscribed!
Keep her coming (Happy New Year!)
Best Regards,
Leon
1970 C/10 LWB Cummins Turbo - Build in Progress
Many other toys as well...
legendary is offline   Reply With Quote
Old 01-04-2011, 11:41 AM   #116
prostreetC-10
My Carbon Footprint
I actually had my buddy convince me that 2 breathers would be enough to bypass the need for a PVC line. He was wrong! Everytime I landed on it, I was spraying a little oil on the valve covers from the breathers. Last spring I decided to pull the top of the ram off and put the port where I wanted it and where it wouldn't be seen. This is where it wound-up.
Old 01-11-2011, 09:16 AM   #117
splehigh
splehigh's Avatar
Your truck is awesome! Going to keep an eye on this one and learn as much as I can. Then maybe I'll build a truck like yours one day.
I knew it wasnt easy getting a tunnel ram with dual carbs to run well but I had know idea at all how it was done. Thanks for the explanation.
splehigh is offline   Reply With Quote
Old 03-07-2011, 12:51 PM   #118
bmfpeterson
bmfpeterson's Avatar
you had me at the 15.5's hahahaha
bmfpeterson is offline   Reply With Quote
Old 03-07-2011, 01:50 PM   #119
prostreetC-10
My Carbon Footprint
LOL......Good one!
Old 06-03-2011, 05:26 PM   #120
thor
thor's Avatar
is it nice and sunny enough for burnout video yet?
1972 Chevy Blazer CST.....Project: Polished Turd
thor is offline   Reply With Quote
Old 06-03-2011, 05:39 PM   #121
prostreetC-10
My Carbon Footprint
Getting there but the truck is still in storage. I'm supposed to get Bonni the chicken soon and will get 'er out for that!
Old 06-03-2011, 05:49 PM   #122
70c10stepside
Nice build, I like them rear wheels.
70c10stepside is offline   Reply With Quote
Old 06-03-2011, 10:50 PM   #123
black_sheep454
Why no pics of tunnel ram through hood
1968 chevy lwb, getting ready to join forces with the 70 gmc
1970 gmc swb, getting ready to be a 68 chevy swb
1971 gmc lwb 2500 2wd Sierra Grande
1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins
black_sheep454 is offline   Reply With Quote
Old 06-03-2011, 11:32 PM   #124
prostreetC-10
My Carbon Footprint
Okay fine!
Old 06-04-2011, 10:48 AM   #125
weaintscared
weaintscared's Avatar
Awesome power house hope mine gets there one day
I need to start myself a build thread
weaintscared is offline   Reply With Quote
