Closed Thread
Old 04-18-2010, 05:18 PM   #1176
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: What did you do to your truck today?
Wrote about it in my build thread!
http://67-72chevytrucks.com/vboard/s...d.php?t=397681
aerotruk63 is offline
Old 04-18-2010, 06:22 PM   #1177
scooterskoolkustoms
scooterskoolkustoms's Avatar
It was a nice weekend here in NJ so I am getting it ready for summer.rebuilding the front end with new stuff 2.5 drop spindles ,cut the springs (for now).pulled off control arms to sand blast and paint,new ball joints, sway bar bushings,tie rods ,inner and outers,new calipers ,pads ,rotors.I hope we have a nice weekend next week so I can start to put it back together again.need to pay for my spindles and see when they come in but it look's like I have a **** load of stuff to do before I'm ready for them.
big old burb in primer.lot of work to do.
scooterskoolkustoms is offline
Old 04-19-2010, 09:31 PM   #1178
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Exclamation Re: What did you do to your truck today?
Fellas,
Well this week end we finally got my Ole' One Bad Mamma Jamma '62 off the jack stands and blew off the dust and swatted some bats away....
We started to kill some cancer in a few areas.
Figured it would be easier to take the windshield out....
I will update my Build Thread soon..... But I worked 67 hours last week and probably do the same this week. Little money....little time....
Well here is what we did so far:
I will post a few for now ,cuz I'm wore slap out and tired.
Take a gander:
Thanks,
One Bad Mamma Jamma
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline
Old 04-19-2010, 09:38 PM   #1179
markeb01
Senior Enthusiast
markeb01's Avatar
Took a load of grass clippings and tree branches to the dumps, giving me an excuse to wash the truck.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
markeb01 is offline
Old 04-19-2010, 09:41 PM   #1180
1Bad62Pro/Street
More pictures:
Old 04-19-2010, 09:48 PM   #1181
1Bad62Pro/Street
This is all for now:
Old 04-19-2010, 09:51 PM   #1182
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
post up all the pics you take of that 62 getting the cab worked on. I have lots of the same rust outs.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline
Old 04-19-2010, 09:51 PM   #1183
sshockr
Nearly got the engine wiring harness completed. Everything under the hood is done now I just need to finish up the portion that runs under the dash to the PCM. I'll try to take pictures later this week. I also made mounts for the 95 camaro radiator and the new fuse and relay panel.
- Brian
1963 Long Bed C10 - LT1/4L60E Swap in Progress. Blew up the straight six and happened to have the engine trans combo on hand already.
1995 Impala SS - LT1/T56 Combo. This is my 1st priority project.
sshockr is offline
Old 04-19-2010, 09:54 PM   #1184
1Bad62Pro/Street
Well.......I have to add these pics for kicks!!!!
Old 04-19-2010, 10:01 PM   #1185
ruffrida2005
when can we expect to see you on pass time?
Paul
Old 04-19-2010, 10:04 PM   #1186
1Bad62Pro/Street
Ok last ones for real this time.....
Taking a few measurements.......
Why......??????
Teehee.......
Guess you will find out later.....
Does Mickey Thompson make running shoes.....
I wear a 10 1/2 D.......Extra Wide
Old 04-19-2010, 10:23 PM   #1187
aerotruk63
aerotruk63's Avatar
At least it's off the jack stands! LOL
Old 04-20-2010, 10:11 AM   #1188
1Bad62Pro/Street
Thumbs up Re: What did you do to your truck today?
Yep....
Been on those off an on for a while now.
It kept the tires from having flat spots on them.
Gonna do some more work on her this wekend.
Old 04-20-2010, 06:21 PM   #1189
jkb
Put the 454/400 in its place.
"All Alone Meet & Greet 2010."
http://67-72chevytrucks.com/vboard/s...d.php?t=393754
jkb is offline
Old 04-20-2010, 06:52 PM   #1190
Chevy Fleetside
Chevy Fleetside's Avatar
I see you cut your firewall like I did.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline
Old 04-20-2010, 07:46 PM   #1191
scotts62
One day...
scotts62's Avatar
You have to slide the engine forward to get the valve cover off or is there enough room?
Scott
93 crew cab build
Project 62
scotts62 is offline
Old 04-20-2010, 08:42 PM   #1192
Chevy Fleetside
When I cut mine, I made sure I could get the valve covers off. I dont know if you can really see it in these pictures or not.
Old 04-23-2010, 10:02 PM   #1193
NF65Fleetside
NF65Fleetside's Avatar
in my old truck i used the CPP/ Truck&Car shop mount kit in the stock location and did not have to do any modifications to the firewall. Also I ran full length headers and power steering too...only minor modification needed was a very very minor notch for the driver side primaries to clear the frame rail.
on another note, I ghetto stitched my seat vinyl with some duct tape and then laid a new wool blanket as the cover....pretty neat fix for the time being, plus side was it was all of $18 bucks and an hour of time.
NF65Fleetside is offline
Old 04-24-2010, 09:52 PM   #1194
NF65Fleetside
New plugs and wires....throttle response and engine idle are waaaay better than before. Although now Im hearing a slight "electric" ticking sound...very faint but its there, could the plugs not be gapped properly? OR could I just be paranoid and my nasty exhaust leak playing with my ears.
Old 04-24-2010, 10:15 PM   #1195
Strodder
Daring to be Different
Strodder's Avatar
Worked on my drip rails, and roof.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline
Old 04-25-2010, 09:58 AM   #1196
halfcockedcustoms
halfcockedcustoms's Avatar
got new rims done
halfcockedcustoms is offline
Old 04-25-2010, 11:04 AM   #1197
sams60gmc
sams60gmc's Avatar
Painted my motor finallly, freeze plugs are in the mail, trying to get it done one of these days.
1960 GMC short fleet, full frame build...
http://67-72chevytrucks.com/vboard/s...d.php?t=329718
sams60gmc is offline
Old 04-25-2010, 10:32 PM   #1198
motiveauto
motiveauto's Avatar
Bought an Arizona hood from Carlisle
86 K20 6" lift
66 C10 LS2 T56
1947 Ford Rat Rod
Softail Deluxe
Softail Chopper
motiveauto is offline
Old 04-25-2010, 10:45 PM   #1199
jbgroby
jbgroby's Avatar
The painted call me and asked me to stop by and sign off on the wet sanding he did. I've never seen the process and am impressed of just how glass smooth it makes the primer.
jbgroby is offline
Old 04-25-2010, 11:15 PM   #1200
Rich 5150 69
Rich 5150 69's Avatar
Started laying dynamat on the floors, will pull the seats and finish the dynamat during the week, I hope install the center consul and carpet during this week as Well.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline
Closed Thread
