Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 07+ Chevy and GMC Message Board
Old 04-20-2010, 04:43 PM   #1
clinebarger
Re: Black & White smoke and a knock?
Check for boost leaks, Do you have a boost gauge? Have you had a scan tool put on it? Just because theres no check engine light does not mean that theres no stored codes.
Does the truck run good?
Hate to say this but it might be a cracked injector body.
clinebarger is offline   Reply With Quote
Old 04-20-2010, 09:28 PM   #2
dgodecke
dgodecke's Avatar
I did put a scan reader on and nothing.
It does run well.
I gave up and took it to the dealer today. $236 later all they could find was cloudy fuel. All the injectors everything checked out good. Put a new filter on it and still the same problem. Well the dealer said to run two clean tanks of fuel through it and if it is still doing the same thing bring it back. I got about 25 miles away when I was passing a truck on a hill in a passing lane. It was smoking but I stayed off the gas enough that it didn't let it knock when the check engine light came on and the power dropped off.
It is back at the dealer and they can keep it until it is fixed right.
07 Chev 2500HD Classic
Project Ranch Hand, Hauling A$$ since 1973
I was told this Project had a L-72 427 425HP, It did not.
It does have a 427 block and parts from various 427 motors. It will end up with a nice strong 454 in the end.
It has not been run for 20+ years
Frame up restoration started2/15/2010
dgodecke is offline   Reply With Quote
Old 04-20-2010, 10:23 PM   #3
clinebarger
It does run well.
If you have contaminated fuel the last thing you want to do is drive it out on a HPCR injected diesel. The tank needs to be drained & flushed. Then hope for the best because a dealer will not warranty injectors when you have contaminated fuel.
Old 04-25-2010, 09:31 PM   #4
dgodecke
dgodecke's Avatar
BINGO! You win the lady a stuffed giant Panda.
It took the dealer 2 1/2 days to find the bad injector. On the bench they all tested out good but when put back in and run up a hill it would throw a code for bad injector. He had to test them one at a time on the road with some kind of rig that required him to remove a bunch of stuff, hook the test rig up to an injector but the stuff back on and go run up a hill. Not only that but he had to test all 8 that way to find what one was different from the rest.
Now we are waiting for a new injector.
I had purchased the extended warranty when I git this truck 8 months ago and it has now paid off. $100 deductible is all in on the hook for.
Old 04-25-2010, 09:55 PM   #5
clinebarger
Thats good news on the cheap injector replacment.
Change your oil & filter, the bad injector was dumping fuel in the crankcase.
