Old 04-13-2010, 01:07 PM   #1
stretch-t
stretch-t's Avatar
Help, 700r4 crossmember, hand brake
Got the engine & 700r4 setting in the frame. Need to build crossmember for transmission and it needs to be that we retain the mechanism for the hand brake. I saw on here a while back that someone had something similar, just can't seem to find it. Can someone point me in the right direction?
Thanks in advance.
1923 T-Bucket Roadster, 383 stroker
1964 GMC Fleetside short bed, small back window, leaf springs.
2000 Fleetwood American Eagle 40' motorhome
stretch-t is offline   Reply With Quote
Old 04-13-2010, 01:53 PM   #2
Clyde65
Clyde65's Avatar
Re: Help, 700r4 crossmember, hand brake
I had the same issue, I installed a 4l60e which is the same as a 700r4, you wont be able to use it unless your real handy with metal fab. I am probably going to go the 66-72 method, all cable around the frame perimiter. If you get better info or a work around, please let me know, cuz I would rather use the stock instead.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 04-13-2010, 06:14 PM   #3
1restorick
1restorick's Avatar
Bowtie Overdrives sell a cross member with the emergency brake mechanism installed. Take a look:
http://www.bowtieoverdrives.com/cata...php?ITEMID=108
Rick
RED RUMBLE
1963 C10 Chevy Truck
Owned since 1984
1restorick is offline   Reply With Quote
Old 04-13-2010, 09:02 PM   #4
65Gregg
65Gregg's Avatar
If I remember correctly I used a regular crossmember and used the original e-brake setup, I did this back in 2001. I will try to post some pictures showing what I did.
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline   Reply With Quote
Old 04-13-2010, 09:19 PM   #5
65Gregg
65Gregg's Avatar
I took these in the dark, maybe you can tell what I did by looking at the bolt locations 1 or 2 of these may be upside down...
65Gregg
Blue long bed
White TBSS
61 Impala
Old 04-13-2010, 11:21 PM   #6
stretch-t
stretch-t's Avatar
Good info coming in! Brain is turning. Can't wait till morning to turn up some tunes and get to building. Got a couple ideas, we'll see what I can fab up. Got metal, welder, torch, and suds, something is bound to get fabed up!
Keep the ideas coming...
Old 04-20-2010, 09:39 AM   #7
stretch-t
stretch-t's Avatar
Well, here's what I came up with. Should work great as it's in the same position as factory only 2" lower. It does not hang any lower than front crossmember, so I'm not too worried about ground clearance. Since I'm not lowering the truck a major amount it shouldn't be a problem.
Old 04-20-2010, 08:18 PM   #8
TR65
TR65's Avatar
Here is what I did to fab up a cross member with stock e-brake.
http://67-72chevytrucks.com/vboard/s...d.php?t=381313
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
