Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 04-20-2010, 09:25 PM   #1
sav300
Drag Racing
I've decided to get into this a little and found out what class I will fit into, but I'd like to get some things figured out. I'm running a healthy 355 in a 3/4ton long box.
-Weight
How much does your pickup weigh? I tipped the scales at 4350lbs with me in it.
-Cam
I've narrowed down my choices to two and want input. Comp cams 275DEH or the XE274H. I have heads that will take more than this, but I'd still like to be able to drive it on the streets.
-Torque converter
I was looking at a 2500 stall for either one, but want to know if it might be a little low. What are the effects of having to high of a stall?
-Tires
What would be a good set of tires to put on that are decent on the street and strip?
-The final question is Nitrous
Would you do it or not? I was considering a 100 or 150 shot if I do it.
Thats all for now and thanks for your input in advance.
Thomas
sav300 is offline   Reply With Quote
Old 04-20-2010, 11:30 PM   #2
rjs53
Re: Drag Racing
what class are you going to run in? sportsman, pro..? I think if your running NOS, NHRA says you run pro or superpro can't remember. also what trans, rearend and gear ratio are you running?
2003 Dodge 2500
1969 C10
2014 Camaro SS/RS/1LE
rjs53 is offline   Reply With Quote
Old 04-21-2010, 12:48 AM   #3
Nick's81
Nick's81's Avatar
Re: Drag Racing
think you could still run dot as long as your tires are dot then move up as your times improve and add goodies
Nick's81 is offline   Reply With Quote
Old 04-21-2010, 03:10 AM   #4
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: Drag Racing
If it were me , i would start out with a set of drag radials and run in a foot brake no electronic class with the tow rig while i was looking for a half ton to build a race truck out of . JMO .
-Weight
-Cam
-Torque converter
-Tires
Thomas
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 04-21-2010, 05:39 AM   #5
shawnt
shawnt's Avatar
Re: Drag Racing
I was consider going with a hydraulic roller. Alot of flat tappet cams have been going bad lately due to not enough ZDDP in oils. JMO.
Shawn
Shawn
85 SWB
7.39 @ 93
Best so far with 0 tuning
Lesson in life: Never fry bacon naked!
shawnt is offline   Reply With Quote
Old 04-21-2010, 09:42 PM   #6
69trk
69trk's Avatar
Re: Drag Racing
shawnt, i see that you are currently in iraq, thanks for serving
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 04-21-2010, 11:53 PM   #7
sav300
Re: Drag Racing
I have a rebuilt TH350 and 4.56 gears inside an HO52. I fall into the unlimited street class.
