#451 |
![]() ![]() Join Date: Jul 2002
Re: Project' 69 c10 aka sin.
Lot of weight for that little motor to pull. The straight six's are not much (sometimes even worse)better that a V8 for mileage. Even in a car, which is still 3000+ lbs to push around. What you getting 12ish to 15ish???
#452 |
less like we put 3 gallons at least in and drove around the block and she was already out of gas.
no idea bad fuel pump?
Smoking Tires Since 1992 1969 c10 AKA SIN 1985 SSWB TRAZER (super short wheel base) |
#453 |
Sounds like something is leaking.
#454 |
HickTown
my guess would be leakage also, my 250 pulls around my c20 and gets fine mileage,
1993 Ford Mustang Vert w/ 2.3 1969 Chevy C/10 w/350 1968 Chevy C-20 w/250 1976 Dodge Aspen W/ 225 2000 Toyota Tundra w/4.7 1987 Dodge Ram D-100 w/360 255/70-15 ___________ (oo)══╬══(oo) ‾‾‾‾‾‾‾‾‾‾‾ |
#455 |
was the tank completely empty when u put the three gallons in? i remember u asking how to drain the tank, if it was the three gallons would barely cover the bottom, and the in tank line and filter don't touch bottom so it may be pulling fumes, not liquid. it may still be leaking lines but the best way is to fill the tank run it around a bit then fill again and calculate mpg if seem excessive then leak probably, plus this motor hasn't run in awhile im sure it will get better once loosen up.
#456 |
Yeah where sure of no leaks.
And I know my truck gets better mpg. Tank was empty when gas was put in seems to just eat it up.
#457 |
HickTown
have you tuned her up? (points, carb, spark plugs, wires, distributer cap and rotor, ect.)
#458 |
Your fuel pump could have some bad sels and pumping it into the crank
#459 |
Got some work done on the truck.. thanks to my old man and brother. i can walk again with a special boot on. Just cut and mocked up. gotta paint the underside of it and where gonna screw it down. also have to fill the holes at the end with steel, planing on welding pieces in just gotta get on it.
pics. looks pretty cool. ![]() ![]()
#460 |
wow! beefy looking what are u using?
#461 |
Grandpa in the rustmobile...
it looks like it would bow under weight, it'll def. be different, wat is it originally?
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#462 |
It's b deck. Like a roofing material 22 gauge. Once we screw of down it will be ridgied. U can walk on it now an it hardly goes anywhere. It was in the yard and free
#463 |
Got some welding done to cap off the ends. Not done yet but getting there.
Hope u all had a nice weekend. I did.
#464 |
Well I just finished up welding the ends shut. I'll get em' painted and have some pics up soon.
U guys liken the look?
#465 |
I like it but looks hard to clean/walk on, wasnt it wood? Id LOVE to have a wood bed they look awesoem!
#466 | |
Yes it was wood.. But wood is expensive and needs to be upkept to last. The wood that was on this truck was rotted bad. But I still have it.
#467 | |
FarmBoy.
That looks clean man. When it's finished, it should be hard to find the seams.
As far as keeping it clean...not at all. a quick hose down while parked on a hill and all the little nasties will come right out. Are you going to thrown some truck bed liner on it,. or some paint..leabe it as it is? Way to use what you have man, that's what it's all about! -Sam.
1969 GMC C1500. long fleet. 307. 3 on the tree. 3.07 gears. Oliver green. Bent and bruised. Daily Driver. Quote:
http://67-72chevytrucks.com/vboard/s...d.php?t=242993 |
#468 |
Thanks Sam.
Yeah that is what it's all about. why go out and spend money when i can make stuff we have sitting around work. I'm plaining on brush painting it with tractor paint on the bottom. and spraying either that tractor paint or using the blitz havent decided yet. but not going to bed line it. it'll be black tho. I got it just about ready to be painted, all the ends are capped off and cleaned up. Personaly i think it looks pretty kick as. random pic i found. i love k5's ![]()
#469 |
Got some work done.
Or should I say painting, under side of the bed is painted black. Should finish up install this weekend. Plates are in the mail!!!!
#470 |
plates for what?
man havent seen you in foreverwhere ya been..WHERE ARE THE PICTURES?!
#471 |
Been busy with school biking and the lady friend. But finally getting something done again. Plates for the truck are in the mail. Can't wait to fill her up. Just in time for 3$ gas prices.
I'll have pics when I install the bed.
#472 |
uh oh lady friend??....does she like old trucks/cars?
#473 |
haha yeah a lady friend
she likes them to a point. she would rather see them all done up than ratty like. haha like ill point out some rusty Chevy running around town and she's like ickky haha oh well shes gotta like them tho. no work today cause the paints still tacky but i should be laying the bed in tomorrow. im screwing it down with self starters so it shouldn't take to long. then im gonna spray the whole bed blitz with the gun. should be fairly nice when im done. and i should be driving it soon.. still trying to find a job. applied a few places waiting on calls back. no plans really. i did find a air cleaner set up that looks more like the stock set up. rather than those to od looking air cleaners. ill toss some pics up the trucks kinda dirty cause we haven't had a break from rain all week... but all in all its holding up to the weather.
#474 |
Some random pics. bed and all
new air cleaner assembly more stock ![]() ![]() ![]() ends all welded up ready to be painted. not screwed down yet but getting closer. ![]() bottom of deck is painted and looks clean. ![]() and my cousin is doing a jeep frame off and just got his frame painted thought i would share. ![]()
#475 |
nice job on the bed! what year jeep? me and my dad are almost done with our 1949 willys cj-2a.
