04-20-2010, 11:03 PM | #1 |
3/4 Ton Rodder
Lund MoonVisor Wiring Help
Hey guys, I'm not sure if this should go here or in electrical.
I have a Lund MoonVisor that I purchased, replaced all the bulbs and lenses, but I have no idea how it is wired because there is only one wire. This wire has to be power because it goes from light to light, but there aren't any ground wires. I am wanting to put this on my truck, but I need to know if I'm gonna have to rewire it before I put it on? So, if anybody here can help me out with some instructions, ideas, or thoughts, please do. This visor has my wiring skills all confused because IDK how it is grounded to the truck with there only being a power wire. Sorry for rambling, just lost. Thanks Benjamin.
1981 Chevy Scottsdale C20 "Orange Crush": SOLD 1989 Chevy Silverado K2500: All Stock (For Now), 350 TBI/700R4. DD/Light Duty Toy. |
04-20-2010, 11:06 PM | #2 |
Re: Lund MoonVisor Wiring Help
Test it first. I would think that they would have to be a ground....
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
04-21-2010, 06:48 AM | #3 |
78K & 79C Jimmys
ones i've seen are not metal so look around the bolt holes is there metal at the bottom of the hole(s) follow to (or from)the other side of the socket....need pics....
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
04-21-2010, 09:52 AM | #4 |
mount is ground
04-21-2010, 12:17 PM | #5 |
Another Day, Another Dollar
ditto to kalishnikov
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box "its hip to be square" |
04-21-2010, 04:32 PM | #6 |
3/4 Ton Rodder
How is the mount grounded????
04-21-2010, 06:10 PM | #7 |
your entire body is a ground. the lights are powered through the power wire, and they are grounded through the visor frame which is attached to the body, therefore completing ground. its kinda like your dome light in the truck.
04-21-2010, 06:57 PM | #8 |
3/4 Ton Rodder
Hmm. Is there a ground wire ran inside the fiberglass? I don't see how it is grounded through the fiberglass unless I guessed right.
04-21-2010, 08:10 PM | #9 |
everything ive seen about MoonVisors is that they have a seperate wiring harness. didnt realize they were all fiberglass.
04-21-2010, 08:22 PM | #10 |
BMW & ASE Master Certified
either way, if its grounded by some mount, i would remove it and run your own ground... dont want to create problems for your lighing later on..
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
04-21-2010, 08:40 PM | #11 |
agreed. if you have a power to the lights. simply run a ground from each bulb bucket.
04-21-2010, 10:05 PM | #12 |
3/4 Ton Rodder
That's what I feared. I just mocked the visor up, and it looks like it may not fit even though it's off a Blazer. I may just end up getting a normal sun visor and adding my clearance lights to the cab.
04-22-2010, 09:47 PM | #13 |
3/4 Ton Rodder
Hey guys, I figured it out. The visor was missing a wire and sure enough it was the ground. So I added a ground and put it on the truck and it looks good, got a bit of a bubble of the drivers side, but I got to live with it.
