Old 05-03-2003, 06:42 AM   #1
skyhawk1
skyhawk1's Avatar
My Suburban died last night!
Coming home from Beckley, WV last night the burb was missing a little (been missing for a few days). It just died while cruising along at about 60 mph. Smelled gas strong when I got it stopped beside the road (it's really hard to stop it when it's not running). Anyway, I thought it was carburator problem because I just installed a rebuilt Quadrajet from Advance about a week ago. So I called home and my sons girlfriend came to pick up my son and me up. We took the Edelbrock that I took off back up and put it on and still nothing. We decided it may be the coil so we went back home and took the coil off my 71 and tried that. Still would'nt hit. Anybody have a clue? Someone told me that my cam lobes may be totally worn off. The burb has the original 350 with 122K miles. It's been running great. Any help would be appreciated.
"The World's a Mess"!
71 C-10
72 Suburban 2WD
Oceana, West Virginia
skyhawk1 is offline   Reply With Quote
Old 05-03-2003, 08:03 AM   #2
pierce
pierce's Avatar
Are you running the original points distributer? My truck just quit after running fine and it turned out to be the points.
69 GMC 1 Ton Longhorn
37 Chevy Coupe
pierce is offline   Reply With Quote
Old 05-03-2003, 08:13 AM   #3
MOTHERTRUCKERS
We had a customers truck do just what you said and it turned out to be a wire shorting out in the distributer itself, he would hit a bump and the motor would shut off.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 05-03-2003, 08:14 AM   #4
racedvl
racedvl's Avatar
Swap the whole dizzy. I bet the something in there went south on ya. I had a problem when my truck just stopped. Swapped dizzys and took the old one apart. A wire had broken off the pick-up coil.
racedvl is offline   Reply With Quote
Old 05-03-2003, 10:37 AM   #5
skyhawk1
skyhawk1's Avatar
I installed a new Accell HEI distributor about 2 months ago. I'm here waiting on the tow truck guy to bring it home right now. He says it sounds like it may have jumped time. I'm going to check that first.
71 C-10
72 Suburban 2WD
Old 05-03-2003, 10:43 AM   #6
No3Fan4Ever
Running on empty
No3Fan4Ever's Avatar
Re: My Suburban died last night!
Originally posted by skyhawk1
Smelled gas strong when I got it stopped beside the road [/B]
Just to be safe, check the fuel pump
We have two rules here at the Rock.
Rule #1: No writing on the walls.
Rule#2: Obey all rules
70 GMC Sierra Grande "Custom Camper" Longhorn 402 Big Block TH400 PS PB factory AC Posi;
94 Bronco XLT 302, auto;worn out daily driver
No3Fan4Ever is offline   Reply With Quote
Old 05-03-2003, 02:01 PM   #7
bpmcgee
bpmcgee's Avatar
You know, I had just exactly the same thing happen to me -- I was driving and all of a sudden it started missing and I smelled gas. I pulled up to a stop sign and it died -- no restart.
I replaced the fuel pump and I've been running fine ever since.
Brian
bpmcgee is offline   Reply With Quote
Old 05-03-2003, 06:22 PM   #8
skyhawk1
skyhawk1's Avatar
I've worked on the burb all day and still no luck. Replaced all 8 plugs, switched carburators, put in a new coil, and new distributor. Sometimes I've got spark and sometimes no fire. I'm totally stumped!
71 C-10
72 Suburban 2WD
Old 05-03-2003, 07:06 PM   #9
Class of 69
Class of 69's Avatar
It seems to me, with everything you've replaced and the intermittent spark, that it's not in the ignition. You need to go back farther in the wiring system to find a short, or broken wire in the power supply to the HEI circuit. Shift your focus away from the motor for now, and look for anything suspicious in the wiring harness. Green corrosion, dark, or black spots from overheating of the insulation etc.
69 GMC K10 ..some restoration required....still..
Class of 69 is offline   Reply With Quote
Old 05-03-2003, 08:10 PM   #10
Hutch
Hutch's Avatar
I would check the fuel pump first.
Then the spark.
If fuel pump is bad you can spray a small amout of starter fluid in the carb for a test.
But stand back away from the engine compartment when trying this test.
Let us know what it turns out to be for future reference.
Have fun
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 05-03-2003, 08:58 PM   #11
skyhawk1
skyhawk1's Avatar
I just got it running but not too good. I replaced the rotor button and it fired up! However, it was missing and ideling rough. I set the timing with a timing light at 8 degrees before top dead center and it seemed to smooth out. I then held the throttle at about 3000 RPM and it ran real rough again, but if I disconnected the vacuum advance hose it would smooth out again. So I plugged the vacuum advance port on the carb and went for a test run and I felt like it was hitting on about 6 cylinders. So I just came home and parked it (I'm tired of fooling with it now) Maybe I'll try again tomorrow or maybe I'll just order a nice crate motor at Advance! I feel it's got something to do with the timing or maybe the cam is worn out or timing chain gears. I would appreciate any advice. Thanks, skyhawk1. Oh by the way, I was supposed to be in Pigeon Forge tonite, I guess that's why this is so fustrating.
71 C-10
72 Suburban 2WD
Old 05-03-2003, 09:05 PM   #12
MOTHERTRUCKERS
Run a wire from your positive battery post to the hei and see what happens, if it starts and runs start chasing wires back through the firewall to the ignition until you find the grounded out wire. Also on an hei system the wire from the ignition out needs to be at least 10 gauge when you convert from points or it will overheat and fry the module over time. In my opinion Accell parts are not worth the money you spent on them but it's only my opinion.
Old 05-04-2003, 12:59 AM   #13
spinning wheels
spinning wheels's Avatar
If its not firing on all cylinders, check for a broken distributor cap. Sometimes the HEI caps get a hairline fracture and thats all it takes to make them run like chit. Also, start it up at night, sometimes you can see if you have bad plug wires that may be arching on something like exhaust manifolds. My truck started running like chit, turned out to be a plug wire got burned on the exhaust manifold. Replaced it, and she was back in business.
'72 GMC custom camper 350/350
spinning wheels is offline   Reply With Quote
Old 05-16-2003, 06:23 AM   #14
skyhawk1
skyhawk1's Avatar
Well after about 3 weeks of trying everything, and nearly loosing a finger I got the Suburban running again. First let me give you some medical advice. I cut my finger on the flex fan right off the bat. It wasn't very deep, so I didn't go to the doctor. Just duct taped it up and kept working. That was on Monday. I had a pair of those mechanic gloves so I wore them most of the rest of the day. By Tuesday evening my finger swelled up and I couldn't bend it. Went to the dr. Wed. morning and he gave me a prescription for an antibotic. By Friday, it was worse. Went to another doctor and he sent me for an xray and MRI. Dr. said I may loose the finger because the infection looks like it's spread into the bone. He put me on a stronger antibotic and I have another appointment Mon. (Still not out of the woods yet) Anyway, the moral of the story: don't play around with cuts, no matter how small. It got infected by putting on those nasty gloves that I had been bleeding in on and off for 2 days. Anyway, the problem with the Suburban was the HEI distributor. I took the stock GM distributor out of a 79 Burb that I have and put it in and it runs perfect. I went through 3 distributors from Advance before finding out they were all junk! One guy at Advance told me that they were junk and he goes to NAPA for his parts.
71 C-10
72 Suburban 2WD
Old 05-16-2003, 09:16 AM   #15
Yukon Jack
Yukon Jack's Avatar
Yikes about the finger! About your distributor, I bought an Accel for the 454 and after enough people sad bad things about their reliability, I returned it unused for an MSD.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 05-16-2003, 09:28 AM   #16
pierce
pierce's Avatar
What happened to quality control? My brand new HEI Accel had a bad diode right out of the box. That was the first time trying to fire up a rebuilt motor.
Get well wishes for your finger also!
37 Chevy Coupe
