View Poll Results: What to do for the rear lift???
Find the heaviest duty 4 inch rear springs I can 9 39.13%
Shackle flip with the original rear leaf springs. 9 39.13%
Original rear springs with a 4 inch block (my least favorite). 2 8.70%
Leave it stock height front and back if I ever want to pull safely. 3 13.04%
Voters: 23. You may not vote on this poll
Old 04-24-2010, 01:04 PM   #1
USSkoval
Re: What to do, what to do? Rear lift question
What length are your springs? 56? I think any rear lift spring is going to ride stiffer than stock. I don't think a replacement 56" is going to be built with a 1/2 ton in mind, no matter who makes it. Nearly all 1/2 tons used 52's.
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'79 K30 Crew Cab Dually
'84 C10 Short Stepside
'88 K20 Suburban
USSkoval is offline   Reply With Quote
Old 04-25-2010, 11:47 AM   #2
Critter
Future TOTM Winner
Critter's Avatar
I have a terrible memory, but aren't all 73-87 rear springs 56" regardless of tonnage? 67-72 rears are all 52.
That's why front lift spring kits with rear blocks are all the same for 67-87, but a full lift kit including rear springs is a different part number from 72-73.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 04-25-2010, 02:00 PM   #3
USSkoval
Nope, most 1/2 tons use 52" rears for '73-'87. Also, I could have swore '67-'72 front springs were a little shorter than '73 and up. I could be wrong though.
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'88 K20 Suburban
