04-24-2010, 09:08 PM | #1 |
Annoying ebrake rattle....
As I have sealed up my 84 4x4, new rattles appear with every improvement. I finally fixed one tonight that had drove me nuts. The rattle always seemed to come from the e-brake assembly and was really apparent if you went over cracked pavement or over lane delineators. These situations are hard to duplicate in the driveway, and I had tried placing a furniture felt between the pedal and the stop it rests against, nothing. Then I tried slicing a vacuum line and placing it against the frame, still wobbled and rattled. So again I contorted under the dash to check all bolts and finally found the culprit. Behind the switch for the brake light when the e-brake is applied is a 1/2 bolt that must be the first bolt they put in when assembling a square body. It took every half inch socket and wrench I had but I finally got it tight..... ah, another rattle sent to its great reward.
04-24-2010, 09:14 PM | #2 |
Re: Annoying ebrake rattle....
I had that same bolt come loose on my 77 and 78. It was a pill to fix, but well worth it!
04-24-2010, 10:12 PM | #3 |
Next project: 1970 K10
Hmmm, I wonder if that's what my rattle/squeak is too? It seems to be coming from that same area.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
04-24-2010, 10:20 PM | #4 |
my e brake cable rattles on my exhaust when theres weight in it annoying as hell
http://67-72chevytrucks.com/vboard/group.php?groupid=37 73 C10 Fleetside If it ain't a Chevy it's foreign http://hotridesmag.com/ |
