Lowering My 96
So i just got a 96 chev, 1/2 ton 2wd standard cab and im wanting to drop it a bit.. im thinking somewhere in the neighborhood of 4/6.. can anyone tell me the best and easiest kit to buy!!
Re: Lowering My 96
ill get better ones this weekend. Going for alignment after work then lower the rear 1 inch tonight
![]() ive been doing kits on these trucks since 93 and sell both belltech and djm. I would go with the djm 4/6 and I beat anyones prices shipped. I know Mike at djm for years now.
2011 CTS-V MODDED 2006 TRAILBLAZER SS TVS2300 BLOWER SOLD 2007 TRAILBLAZER SS 11.7@117 1.817 60' Wifes Daily |
Frequent Flyer
Re: Lowering My 96
I generally use BellTech or Western Chasis but have used DJM in the past also.
My daily is 5/7 dropped with all Western Chasis & I'm very pleased. The notch with the Western flip kit seems to be larger because it doesnt bottom out as often as other trucks I've had with the BellTech notch. ![]() ![]()
Re: Lowering My 96
DJM, Western Chassis, BellTech or McGaughy's and you can't go wrong.
Personally, I would avoid BellTech spindles because they push your front wheels out slightly and might give clearance issues with some wheel/tire combos, but if that's no concern for you, then no worries. |
Old Skool Club
![]() Join Date: Jun 2001
Re: Lowering My 96
This link is in another post.....It is recommended reading if you want to know what to do.
http://docs.belltech.com/66056607-888.pdf
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Re: Lowering My 96
NorCal.. tell me roughly what a complete kit including shocks would cost me.. that would be great..
![]() Join Date: Apr 2008
Re: Lowering My 96
Hey jwall what all did you use in the fron for your drop? what size tires are you running?
#8 | |
"Oh well, it's a driver."
Re: Lowering My 96
Matt, welcome to this side of the board! And now, because somebody has to do it...
- JB - '93 C1500 SHORT/FLEET SILVERADO, 350/4L60E ![]() Quote:
#9 | |
Re: Lowering My 96
the belltech is a few hundred more i just need to know if you want to go with spindles/springs or a arms and springs
#10 | |
Frequent Flyer
Re: Lowering My 96
255/60/15 front & 275/60/15 rear |
Re: Lowering My 96
spindles and springs... !!
Mr. Thread Killer
Re: Lowering My 96
Which combo provides the best ride/comfort for the 4/6 & 5/7 drop?
Matt, what size wheels will you be running, 20's? |
Re: Lowering My 96
Blitz.. i will prolly be running the stock wheels for a while.. i have a set of 17s i might put on it..
#14 | |
Re: Lowering My 96
For the rear, you'll have a flip kit for 6" and then you'll add a pair of shackles in the 1" hole to the flip kit to get your 7". In the front, 2" spindles and springs. 2" springs for a 4" drop or 3" springs for a 5" drop. DJM makes 2" and 3" lower control arms, but DJM doesn't recommend using them with drop springs. I have seen some serious balljoint issues from people who do use them with springs. |
#15 | |
Mr. Thread Killer
Re: Lowering My 96
#16 |
Re: Lowering My 96
I will also add that you CANNOT use the drop control arms with drop spindles. This combination will have your spring pocket hanging so low that you'll be popping the reflectors on the street.
#17 |
Mr. Thread Killer
Re: Lowering My 96
![]() Noted. |
#18 |
Re: Lowering My 96
yeap very true, drop control arms are the way to go. if you want to be cheap about it you can get a set of 3/4ton coil springs and cut them. i ran a cut set with my drop control arms and liked it. the truck felt more stable in the corners along with the sway bar.
#19 |
Re: Lowering My 96
How many coils did you cut off?
#20 |
Re: Lowering My 96
#21 |
Re: Lowering My 96
#22 |
THE VILLIAGE IDIOT
Re: Lowering My 96
hey peeling reflectors off the high way is fun, well until mr policeman sees you doing it an figures out your the one responsible for most of the missing reflectors,,lol........i have cut coils for a lincoln i had one time, rode pretty good... was gettign ready to cut the coils on my van until i ran into a super deal at wal mart for 2 tires, they were 15's like i needed, but to big to do a drop now, oh well next spring..
honestly honey,,i have no idea how that truck got here.
| Bookmarks |
