Old 04-25-2010, 11:23 PM   #1
coater
Time for new gauges! Before new engine.
I have a '85 Silverado with the factory gauges,and want to upgrade to a newer style gauges that will fit in the original holes in the dash. Would like something with easy hook up and be accurate.
Any recommandations?
Thanks Coater
coater is offline   Reply With Quote
Old 04-26-2010, 01:52 PM   #2
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Re: Time for new gauges! Before new engine.
Anyone?
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 04-26-2010, 02:20 PM   #3
ECU PIRATE
ECU PIRATE's Avatar
I have been contemplating an Auto Mete gauge set up from Summit. Looking @ 2 5/8" gauges for the fuel, oil pressure, volt/ammeter, water and 5" gauges for the Speedo and the tach. Should run about $ 300-400 dollars depending on the model. They sell the 2 5/8" set up (3 gauges) for about $ 45.00. That tach and the speedo is where all of the money goes
The Fleet........
68' Camaro - 1st car (restored & still have it)
09' VW Tiguan (Wife's Daily Driver)
14' VW Passat SE TSI (my personal)
14' Ford Edge Sport (Daily Work Vehicle)
73' SWB Stepside - 77K org. miles
74' LWB 454/TH400 - drive train transplant for my (Sold)
98' SWB C1500 W/T - shop truck (Sold)
90' GMC Sierra SLE short step - aka " Jezabelle " (Sold)
ECU PIRATE is offline   Reply With Quote
Old 04-27-2010, 11:43 AM   #4
coater
Do those set on top of the gauge panel or recess in like the stock ones?
Old 04-27-2010, 11:50 AM   #5
Jonboy
Slots go on anything!
You can do them either way.
http://www.73-87.com/7387garage/inte...s_recessed.htm
or
http://www.73-87.com/7387garage/inte...ge_surface.htm
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 04-27-2010, 09:47 PM   #6
coater
Thank You so much!
Old 04-28-2010, 10:06 AM   #7
lifted87
lifted87's Avatar
heres mine and i think this is what your looking for. i went with all auto-meter pro-comps the oil and water are liquid filled and i ended up changeing the speedo to a electronic because you can program it to any tire size and if you change tire size you just reprogram it.
87 gmc with a 383,6 in lift,everything new inside and out.
lifted87 is offline   Reply With Quote
Old 04-28-2010, 12:23 PM   #8
JohnC
JohnC's Avatar
Usually I don't like the gauges mounted on the front side of the bezel, but your setup looks really good with the wood grain. Nice job!
JohnC is offline   Reply With Quote
Old 04-28-2010, 02:33 PM   #9
coater
I agree! It looks nice with the wood grain.I also have the factory clock in my dash. Do they make a clock also?
Old 04-28-2010, 10:04 PM   #10
lifted87
lifted87's Avatar
auto-meter does just, not in that series. i think sport-comp series does offer one.
