Old 04-26-2010, 04:26 PM   #1
Mark B
Mark B's Avatar
How to I reduce slack in steering?
My steering wheel has about 3 inches of side to side play before any actual steering happens. What is the solution to take out slack? My truck is 1970 C10 with original manual steering.
thanks
Mark
Mark B is offline   Reply With Quote
Old 04-26-2010, 04:38 PM   #2
ubtripn
ubtripn's Avatar
Re: How to I reduce slack in steering?
Hi there, I'm sure that you will receive a lot of good technical advice that is better than mine but I have learned one thing from past vehicles and that is that replacing the Idler arm can take out a ton of play and doing so gives a lot of bang for the buck. Of course there are other steering/front end components one can go through as well but simply doing this one thing has turned cars from undriveable to drivable for me.
ubtripn is offline   Reply With Quote
Old 04-26-2010, 05:07 PM   #3
Shaky
Six in a row makes it go...
Shaky's Avatar
If the idler arm is good and it's the box that is sloppy, there are instructions in the service or overhaul manual on how to adjust the worm rack (slotted screw with jam nut). My experience has been that you only get so much out of this - it won't perform a miracle.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 04-26-2010, 05:14 PM   #4
cdowns
cdowns's Avatar
tyrod ends idler arm pitman arm and ball joints all may have wear after 40years
that steering box adjustment is a very stopgap method at best// it can cause alot of pressure on the worn box and lead to a steering box failure at the worst possible time
Old 04-26-2010, 05:21 PM   #5
CARR33
First try adjusting the steering box. On the top of the box is a threaded stud with a slot cut accross the end facing up. This stud is kept from turning by a lock nut at its base. This stud takes the slop out of your box. Jack the truck up so both wheels are off the ground. Make sure nothing has been placed in the way of any parts that will move when you turn the steering wheel lock to lock. Now loosen the lock nut and while holding the lock nut with a wrench use a big flat blade screwdriver inserted into the slot of the stud and turn the stud in (clockwise). Try 1/2 turn and see if the steering has gotten any better. Keep going in 1/2 turn increments until you have gotten most of the slack out. If the screw gets tight (meaning you have meshed the gears completely tight) stop and back off 1/2 turn. You only want to turn the stud in until you have taken the slop out. Once done tighten the lock nut down and turn the steering wheel slowly from lock to lock feeling for any tight or binding spots. If there are any loosen up the lock nut and turn stud out another 1/2 turn. Any tight or binding areas could cause the steering wheel not to center properly while driving or completely lock up on a turn. While the truck is jacked up check all steering components also. The idler arm is a good place to start as stated in a thread earlier.
CARR33 is offline   Reply With Quote
Old 04-26-2010, 05:27 PM   #6
LockDoc
The Older Generation
LockDoc's Avatar
If you tighten it up too much, when you turn a corner you won't be able to straighten it up and you will drive through a fence and almost hit a tree... Ask me how I know..... (on second thought, don't)
If it is the steering box that's bad go to your friendly auto parts store and buy a replacement.
LockDoc
Leon
Old 04-26-2010, 06:31 PM   #7
Wrenchbender Ret
First jack it up & get under it. Start pulling & pushing all the joints & kingpins. Anything with play or looseness needs to be replaced. With that much play I'm sure it or most of it is in the steering gear. If it was a small amount you can adjust it but with a lot of play it needs to be rebuilt. They are not that hard to rebuild & when the front end on these trucks are right they are a pleasure to drive.
Wrenchbender Ret is offline   Reply With Quote
Old 04-26-2010, 08:47 PM   #8
Mark B
Mark B's Avatar
Re: How do I reduce slack in steering?
Thanks to everyone who replied. Where does one go to get a replacement new or rebuilt steering box?
Old 04-26-2010, 09:08 PM   #9
cparman
sharp as a marble
all of the above.
If you have a jack and two jack stands ( to be safe)
Jack one side of the truck at a time:
get the jack as close to the lower ball joint as you can. Once the wheel is off the ground, take a long pry bar, and raise and lower the tire at the 6 oclock position. Have someone looking for loose play in the upper and lower ball joints. Then take your hands and grab the tire at the 3 and 9 o clock position and have someone look for loose play in the steering linkage. if something is loose, then fix it.
IF the steering box is worn out, you should be able to turn the steering wheel, and see the steering shaft move all the way to the top of the steering box. Then you will see no movement at the bottom of the steering box.
Adding power steering to our truck is pretty simple. go to the local parts store and buy a reman power steering box $200-$250. then it gets a bit hard. you will need a P/S pump,pulleys,hoses, and some fluid. I will tell you that you will be glad you did this !!
cparman is offline   Reply With Quote
Old 04-26-2010, 09:15 PM   #10
cdowns
cdowns's Avatar
autoparts store
Old 04-26-2010, 09:34 PM   #11
70C10Toejam
Hellasick
70C10Toejam's Avatar
LockDoc
Oh come on....please tell!!!!!
Or wait and tell it around the campfire.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes)
This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do.
RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!!
BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys
70C10Toejam is offline   Reply With Quote
Old 04-26-2010, 09:59 PM   #12
vectorit
What?
vectorit's Avatar
hmm 3" isn't too bad, and I'd think you wouldn't want to have a completely snug steering with a manual box. Since if you hit a curb, or rock it could jolt your steering wheel abruptly enough to hurt your hand.
<I'm no expert, so I may be TOMA>
So...
As far as getting a new rebuilt steering gear, just about every one of the resto parts vendors carry those. So pick yer poison.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 04-26-2010, 10:26 PM   #13
LockDoc
LockDoc's Avatar
I vote for the second option. I'm a two finger typer..
LockDoc
Leon
Old 04-26-2010, 10:56 PM   #14
72lb4x4
Originally Posted by cdowns View Post
autoparts store
Some of your posts just crack me up!
72lb4x4 is offline   Reply With Quote
Old 04-27-2010, 09:14 AM   #15
KEL
72 GMC
KEL's Avatar
http://www.scribd.com/doc/6829240/Sa...Rebuild-How-To
KEL is offline   Reply With Quote
Old 04-27-2010, 02:52 PM   #16
barryvanhook
barryvanhook's Avatar
I've seen listings for "quick ratio" boxes in some of the catalogs catering to our trucks ... the claim is about 1 turn less, lock-to-lock. Any experience?
Barry
Barry L. Van Hook
'69 Chevy Frankentruck
barryvanhook is offline   Reply With Quote
