Old 04-26-2010, 09:51 PM   #1
tucsonjwt
Headliner
I need to replace the headliner on my 83. It has the factory padded headliner but the fabric is gone and the foam padding is pitted/crumbling. What is the cheapest/best replacement?
tucsonjwt is offline   Reply With Quote
Old 04-26-2010, 09:53 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: Headliner
try captkaos our site vendor otherwise you can try to find a good foam in the boneyard and get material at a fabric place and attach it with spray adhesieve
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 04-28-2010, 06:30 PM   #3
tucsonjwt
Re: Headliner
Anybody try a headliner repair kit, for about $45-50?
Old 04-28-2010, 07:53 PM   #4
RandyP
Getting Old; Going Broke
RandyP's Avatar
Re: Headliner
Upholstery shop will redo it for like $50 to $75.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 04-28-2010, 10:11 PM   #5
lifted87
lifted87's Avatar
Re: Headliner
i got one from lmc truck and it fit perfect and looks great. only downside is it was $250
87 gmc with a 383,6 in lift,everything new inside and out.
lifted87 is offline   Reply With Quote
Old 04-28-2010, 11:30 PM   #6
shloopter
Re: Headliner
I bought some material on Ebay. Search "headliner material" and it's from a really nice guy from Chico, CA. The material cost me 2.99 plus 6.00 shipping. I scraped the headliner with a wire brush to get it clean, then I glued it to my very weathered foam molding with scotch super high strength spray glue. It came out pretty good. The material I bought was some kind of blowout. Most of his stuff is around $15 and up.
shloopter is offline   Reply With Quote
Old 04-29-2010, 12:54 PM   #7
tucsonjwt
Re: Headliner
I just dropped my headliner off at the local upholstery shop that rebuilt my seat. $55 for OEM like headliner. It turns out that my headliner is on a soft fiberglass base (like dense insulation) - made it easy to remove (did not have to remove the seat belt bolts (impossible to turn out). However, there is a residue of the old liner stuck to the fiberglass which the upholsterer said had to stay on the fiberglass, because the new liner material would not stick to the fiberglass well. So, I figured I would leave this in the hands of a professional.
The only kits I saw were like $40 - $55 with shipping. Too bad I did not see the cheapo Ebay post below first.
Old 04-29-2010, 07:16 PM   #8
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: Headliner
we sell headliners covered for about $130 + shipping:
http://store.73-87chevytrucks.com/me...y_Code=7387INT
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 04-29-2010, 11:00 PM   #9
Eighty-6
Re: Headliner
how much would a black on be shipped to 78665?
Eighty-6 is offline   Reply With Quote
Old 04-30-2010, 12:50 AM   #10
tucsonjwt
Re: Headliner
I guess the big difference on these later model square bodies is that the OEM headliner is soft fiberglass and the replacements Captkaos has are on a hard ABS backing. Sounds like the ABS backing is better, but in my case, recovering the OEM fiberglass was better because I could not get out the seat belt bolts in the cab to remove the plastic trim in the corners. The soft fiberglass will bend enough to get over the plastic corner trim without removing it. I wanted perforated vinyl like my old 73 had but the upholsterer said it would not stick to the fiberglass.
Old 05-22-2010, 07:41 PM   #11
Goldfinger
Goldfinger's Avatar
Re: Headliner
Honestly i would strip the adhesive left and paint it to match the interior. metal roofs are great.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 05-22-2010, 10:34 PM   #12
tucsonjwt
Re: Headliner
I wish the entire interior was metal like the old trucks - dash, door panels, headliner. But in AZ desert I do appreciate the insulation effect of the headliner fiberglass backing.
