Old 04-27-2010, 07:27 PM   #1
k5blazin
posi front axle?
picked up a 71 k5 for parts! the options list front and rear positraction axles! is this common? also was there ever a factory gm snow plow? the reason i ask this is because there are a few decals stating plowing precautions that look GM!! thanks
k5blazin is offline   Reply With Quote
Old 04-27-2010, 11:46 PM   #2
Jtrux
I'm a poor spectator
Jtrux's Avatar
Re: posi front axle?
I've only heard of one other having it so I would think it's not common. My Ford F150 has front and rear limited slips and it's pretty uncommon in Fords too. Looks like it could be fixed up. Oh and the plow could of maybe been dealer added.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 04-28-2010, 12:03 PM   #3
JimmyFloyd
If you aren't using some parts from it, I might be interested in what is left, and you aren't too far from me. Let me know.
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3
JimmyFloyd is offline   Reply With Quote
Old 05-05-2010, 10:59 PM   #4
budster
My 72 Blazer has front and rear posi, it was just a special order thingy.
budster is offline   Reply With Quote
Old 05-05-2010, 11:20 PM   #5
Critter
Future TOTM Winner
Critter's Avatar
Is that top yellow or am I seeing things?
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 05-07-2010, 09:27 PM   #6
k5blazin
yes its john deere yellow!! painted by the original owner years ago... its a double wall factory color was black!
Old 05-07-2010, 09:32 PM   #7
k5blazin
took the body off this past weekend!
Old 05-10-2010, 09:25 AM   #8
JimmyFloyd
what'd you do with the body?
Old 05-10-2010, 10:00 PM   #9
k5blazin
stripped what i needed and set it aside! what are you looking for?
Old 05-10-2010, 10:27 PM   #10
I had a Custom Camper/10 with front and rear posi.It`s a rare option to find.
Old 09-11-2011, 09:41 AM   #11
115-K10
115-K10's Avatar
Hi, I know this is an old post but do you still have the plow setup and if so do you want to sell it?
Thanks,
Jeff
The chum Bucket - SWB K10 Restoration - http://67-72chevytrucks.com/vboard/s...d.php?t=329775
1971 SS454 Monte http://www.hemmings.com/mus/stories/...feature14.html
1970 - Monte Carlo Convertible, LS6, L89, M22 Build
http://www.firstgenmc.com/ubbthreads...=360236&page=1
1970-SS454 Tripe Black - Barn Find
http://www.firstgenerationmontecarlo...=421201&page=1
115-K10 is offline   Reply With Quote
Old 09-12-2011, 08:14 PM   #12
k5blazin
Old 09-12-2011, 08:15 PM   #13
k5blazin
Sorry plow set up is gone!
Old 09-14-2011, 05:29 PM   #14
viking427
Not to put an old thread on life support, but a quick question on the front Positraction option (I think I know the answer);
Does this mean the standard 69-72 4WD Blazer front differential carrier is actually an open unit ..meaning only one of the front locking hubs (front left I assume) is operational and the other locking hub is just for looks and useless ?
If so, I guess the base model 4wd is actually just a "2WD", unless it came with the rear posi option, in which case it would be 3WD ..unless it also came with front posi option, making it a true "4WD"
And how do open front and rear diff. carriers behave in reverse, I assume the same as forward (same wheel spinning, only backward).
..guess I haven't expiremented enough.
viking427 is offline   Reply With Quote
Old 10-10-2011, 10:56 PM   #15
69TowRig
Both hubs are functional. Both have shafts running to the differential. As long as both tires have traction then both tires get torque from the driveline. When one tire or the other hits a slick surface (or is lifted off the ground) then the open differential will drive that side. The purpose, of course, is to allow for speed variation between the wheels while driving on a surface with sufficient traction. In a turn the outside wheel travels a longer arc than the inside wheel so the differential allows the outside wheel to spin faster than the inside wheel. Unfortunately this also means in low-traction situations that it will push engine torque to whichever wheel has the least traction.
Yes, stock carrier is open, and the Posi units are a bit rare.
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
