04-28-2010, 11:11 AM | #1 |
"brand new second-hand"
am/fm install and help question
Hey everyone-I'm going to install an am/fm radio to replace the am only unit. I have two questions cause I'm not a radio guy-can I use the same antenae or do I have to get a Fm piece-also what speaker do I need (factory) ohms?
Steve 69 3/4t custom camper tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c 67 Camaro 96 Impala ss-sold 04 hybrid Honda-saving gas for the blue truck!:b69: |
04-28-2010, 12:35 PM | #2 |
TILT COLUMN GURU
Re: am/fm install and help question
Speaker and antenna are the same.
kevs_classics64 64 Impala SS Conv 72 Blazer 2wd 75 Jimmy 2wd 63 Belair wagon 02 Silverado ext cab. DD RIP EL JAY |
04-28-2010, 12:50 PM | #3 |
What?
The original speaker is not the same as what the regular speakers are out there on the aftermarket.
Are you going to an OEM AM/FM radio? If you are, and going in the direction of restoration to OEM style radio set up. Then check these guys out, they have the OEM speakers and are pretty informative on questions you may have around OEM radio's. http://www.turnswitch.com/speakers.htm
Chris 1968 K20 Suburban 1972 K10 LWB PU |
04-28-2010, 01:10 PM | #4 |
I just ordered one from the above mentioned link. He's currently ou of our in dash speakers. Next production run is next week sometime.
04-28-2010, 01:17 PM | #5 |
Thanks Vectorit! thats just what I needed.....Steve
