has anyone ever seen this done!!!!
Ok PO which was wifes stepfather lowered the truck old school.... the back he took out some leaf springs..... The front has got me totally confussed... i have pics of what I'm talking about but just don't look right.... take a look at these pics and if you can explain why this was done..........
this is the passenger side where the upper a-arm look at the rubber spacers?? driverside samething why was this done!!!!!
http://67-72chevytrucks.com/vboard/group.php?groupid=37 73 C10 Fleetside ![]() If it ain't a Chevy it's foreign ![]() http://hotridesmag.com/ |
Re: has anyone ever seen this done!!!!
the shims is that what your talking about...? the shims are added and removed for caster camber adjustments, they had to put an ass load of shim because it had negative camber.
oh and i'm pretty sure their metal shims
The One And Only !!!
![]() They have nothing to do with the drop on the front other than re-aligning the front end, Looks like you will need to replace the upper control arm bushings soon too.
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
alot needs replacing but all the trucks i seen did not have this done... i think the way it was lowered has something to do with this it's crazy looking
#6 | |
That's exactly right, When springs are cut or drop springs installed more shims are required to get the tires straight again.
Addicted to Rust
![]() Join Date: Dec 2009
Thats why I stretched my upper a arms. It would have taken 1 3\16 worth of shims to get the camber close.
Current trucks: (48 GMC100 320 inliner) Gone (48 Suburban in pieces) Sold 87 GMC CCSB 5.3 4l60E Daily Driver ECTA National record holder XO/PP We never really grow up, we just learn how to act in public. |
The 77 short bed I have has a Mr. Gasket part that they used back in theday . It bolts on where those shims are and extends the a-arm outward . The original owner lowered it in the late 70's when there were no spindles. He said they made that piece to fix the upper a-arms on lowered trucks . He also flipped the rear and added helper springs to keep it from bottoming out . Pretty cutting edge for the time it was modified.
Frank
Born and proudly residing in a Red State ! |
#9 | |
Next project: 1970 K10
The only thing that looks off to me is that they appear to be body shims instead of alignment shims. This is my stock 91 Suburban, not lowered:
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
Looks exactly like whats on my stepside...it was lowered with drop springs in the front and lowering shackles out back.
Happy to be here
![]() Join Date: Mar 2000
I am going to guess that it rode like a brick. What puzzles me is the fenderliner cut out.
that is what i first saw too ??? |
1962 C-10
Mine's also shimmed. It's normal...
Joseph Chavez ![]() "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
i don't know i need to put it back to stock height and start over and do it the right way
#15 |
My 82 with HD Coils (not lowered) was the same way..
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
