Old 04-28-2010, 12:10 PM   #1
rgreathouse
Dodge Ram Chassis under 72
Anyone have any idea how similar a 94-97 dodge ram 4x4 standard cab chasiss is to a 67-72 c10 cab and front clip?
Basically there is a 94 dodge ram 4x4 cummins 2500 standard cab long bed with very low miles for sale real cheap because it was in an accident, no damage to front clip or frame.
Soo I have a very clean 72 cab and front clip along with a flat bed laying around. It would be awesome to have a 4x4 cummins powered chevy with a factory four link dana 60 front end. I know it would take some work including new body mounts and much more.
lemme know what you think
Robert
1972 c10,2wd,long bed,250,4spd---->
1972 SWB Fleetside 4x4 12v Cummins build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=513791
rgreathouse is offline   Reply With Quote
Old 04-28-2010, 01:43 PM   #2
Danny Bost
Danny Bost's Avatar
Re: Dodge Ram Chassis under 72
Ambitious project, but I would love to see it complete.
Danny
71 SWB
Danny Bost is offline   Reply With Quote
Old 04-28-2010, 02:33 PM   #3
Ackattack
Ackattack's Avatar
I wanna do this too, but put a suburban body on it.
I know on "Trucks" they were putting a mid-70s ford crew cab onto a later cummins dodge chasis. The had to move the mounts around a little, but didn't seem that difficult to me.
Ackattack is offline   Reply With Quote
Old 04-28-2010, 03:43 PM   #4
68 TT
Still plays with trucks
68 TT's Avatar
The only real hurdle is the frame rail width and length but since you want a flat bed only the width really matters.
From what I was able to find the Dodge frame is about 37.4" wide and the wheel base is about 134.7" for the regular cab long bed.
With our rails about 34" you will need to fab up some custom frame stands for the cab & core support mounts to fit the width & contours of the Dodge frame. Shouldn't be too hard.
The worst part would be making sure you could get the front wheels centered in the fender wells and still have the Cummins clear the core support & firewall without major frame surgery.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 04-28-2010, 04:25 PM   #5
D-Rat
D-Rat's Avatar
I saw a 71-72 sitting on an 88+ shortbed chevy chassis the other day...IFS and all. It had to have a ridiculous body lift to clear everything....IMO it looked terrible.
If it all fit though, that would be one cool truck.
1970 CST with a screaming 400
www.nissan4wheelers.com
D-Rat is offline   Reply With Quote
Old 04-28-2010, 08:50 PM   #6
8mpg
8mpg's Avatar
I was going to do this but just ended up putting in a 12 valve cummins in the 69 frame. From what I kinda gathered, the motor will need to be pushed back a couple inches to fit or you are going to run into problems with the fan and the radiator. You cant really do a pusher fan well due to the intercooler.
Shortening the frame is no big deal, trimming fuel lines and brake lines are fine. You will have to build cab mounts...again, not to bad. If you run a 4x4, it will be ok, the frame shape is different and you would essentially have a body lift.
For what its worth, I think it is really just easier to use a stock Chevy frame.
I have a build thread started in the projects section for me 12v conversion.
8mpg is offline   Reply With Quote
Old 04-28-2010, 09:50 PM   #7
Dodge frames are oddball wide.I wouldn`t think it`s worth it when you can use your frame.
Old 04-28-2010, 11:24 PM   #8
Ackattack
Ackattack's Avatar
don't you run into problems using the 67-72 frames with the AC comp. on the cummins hitting?
Old 04-29-2010, 12:15 AM   #9
tomtuna1978
do it do it do it !!! and take lots of pics and show us how you did it ! just remember to be verry enginueatis (i know i spelled that one wrong lol) and do all the fab work the rite way and dont hack it !
tomtuna1978 is offline   Reply With Quote
Old 04-29-2010, 02:00 AM   #10
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
It has been done over in the 4x4 section already. It was a chopped cab on a dodge frame. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 04-29-2010, 03:00 AM   #11
darthwall
I would say go for it sure your goingto run into some snags but the cummins is alot better engine than the old 6.5
darthwall is offline   Reply With Quote
