Help with rearend identification
Hi guys, im trying to find out the specs of the 12 bolt rearend i removed from my 67 chevy c10 1/2ton swb. Here what i see on it:
HA 09 01 W (on the pside axle shaft) 3896838 ( on the diff housing) Any ideas what i have or where i can look up these #'s. Thanks, Chris. |
Active Member
![]() Join Date: Oct 2002
Re: Help with rearend identification
If you remove the rear inspection cover you should have a code stamped on the edge of the ring gear, one is a date code, the other is a tooth count, 1 for the ring and 1 for the pinion, if you divide the 2 numbers, this will give you the rear end ratio.
I cant remember how to read the codes that you found on the axle housing. |
member #16
![]() Join Date: Dec 1999
HA is a 3:73.1 ratio . The only way to tell for sure in a forty year old truck is to pull the cover and look. The HA code shows in several yr. model trucks including 1967.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ Last edited by john; 04-30-2010 at 04:22 PM. |
b4 pulling cover have a drain pan also a spray can of brake cleaner , a new gasket and 2quarts of reargear lube
