4" lift on 35's?
Anyone got pics of a 4" lift on 35 inch tires? I got a 83 and i was thinking of this setup, but i want to see what it looks like. Any pics will help thx
'83 gmc high sierra swb 4x4 ![]() |
Redneck Customs Bumpers, IA
Re: 4" lift on 35's?
how bout a 91 burb
Here u go...
![]() ![]() Same truck with 5" lift, 37's, and cucv running gear. ![]() Last edited by jkade; 04-30-2010 at 10:40 AM. |
Any rubbing issues with the 37s?
70 stepside 76 blazer 86 Silverado 20 Max Trailering 6.2 Crew 71 Nova SS My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634 |
76 K20 with 4'' & 35's
![]() ![]() The PO cut part of the front fenders. I don't know if he experienced rubbing and cut, or cut while doing the lift. ![]() |
well im sold. love the trucks.
Sb 400 club
I am running 4 inch lift with 34x10.5x 15 swamper tsl's and I have never rubbed. I wheel this truck pretty hard and never hit fender
http://hphotos-snc3.fbcdn.net/hs138...._7922152_n.jpg
![]() ![]() 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed ![]() 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
#8 | |
[IMG]
![]() My truck has a 5" lift with 285-70-17's on it. Tires are a little small for my taste(about a 33" tire), but they have a ton of tread left so i'll wear them out and then put 35's on.
'59 Apache - 383" SBC/TH-350 '68 GMC - BBC/TH400 |
Nah, nothing major.. I pulled that setup out of the truck and put it under military blazer with 38's and I need to do a little trim as they do rub a little at full lock when it a bind.
37's ![]() 38's ![]() Last edited by jkade; 05-03-2010 at 09:28 PM. |
Displacement4me,I love that truck,especially in the first picture.
Here`s a couple of mine I`ve done: ![]() ![]() ![]()
To every one running 4 inch lifts with 35s do you have any rubbing issues.. right now im on a rough country 4 inch lift with 33's but am changing to a skyjacker 4 inch lift and am wanting to run 35's just a lil concernd with fitment issues and rubbing issues
84 Short bed 350: Hooker headers, flow master 40 series, edelbrock Intake manifold, Holly street avenger carb, 4 inch skyjacker suspension lift, 33x12.5 Toyo Open Country Mud Terrains, 3.73 gears ![]() 2011 Silverado LTZ |
35" is the largest tire series for this class and 4 " lift doesn't give any of the issues on 35"... but yes if 3" lift I have seen many of them not going good... best of luck!!!!
White 82
heres mine 1/2 ton 4 in with 35s mine has rubbed when i was hard coring it through washouts on galveston beach one year.. almost dragged the back bumper off going through them..
1966 GTO 455 e-heads, 1982 Chevy k10 4'' lift 33’' tires, 2008 Pontiac g6 v6 Last edited by white82; 12-27-2010 at 01:41 PM. |
#15 |
[QUOTE=special-K;3958722]Displacement4me,I love that truck,especially in the first picture.
Here`s a couple of mine I`ve done: ![]() Whats the spec's on these wheels as far as backspacing and width? Are the stock with fat tires? Thanks for the info |
#16 |
my burban has 4in suspension with 3in body and 38.5s no rubbing except when i ramped a hill climb and bent the back bottom edge of fender
Posted via Mobile Device |
#17 |
My 82 on a 6inch but is coming down to 4, on 35"
2004 Silverado Crewcab 1972 Chevy Monte Carlo 2017 Chevy Tahoe |
#18 |
I am running a 4 inch lift and 35s in my 78 k15 and didn't have issues until I went to 15x12 wheels with 3.5" back spacing
#19 |
does the brand of the lift make a difference on what will fit?
#20 |
K5Camper
![]() Join Date: Mar 2004
4 inches is 4 inches. 35's will fit on just about any 4" lift. However, some of the softer brands might allow for more flex that might put the tire in contact with the fender with the wheels turned.
Mine didn't rub with 4" rough country springs and a shackle flip out back. That being said I chopped the bottom 4"s from the front of the fenders. I did that due to rust in the fenders but also because they were close enough to touch the tires off road I chose to lop them off.
Rob Z. 1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP 1991 K5 8.1L/NV4500/241/D44/14b FWC Camper |
#21 | |
#22 |
also was the shackel flip hard to do?? it looks pretty cool, but i dont want it to sag at all in the rear
#23 |
K5Camper
I don't feel that my Rough country springs are overly stiff. They are firm, don't get me wrong but they aren't rattling my teeth out either. There are softer setups for sure but these don't bother me. Having the shackle flip out back helps the overall ride quality too though.
My shackle flip brackets are different in style than ORD or DIY4X hangers. Mine were built by a now defunct fab shop called Echobit. They use the stock spring hangers and bolt on where the shackle used to sit and extend down to let the shackle bolt up under the bracket. For mine all it took was pulling the shackle bolt to the spring hanger, flipping it under and bolting the flip bracket in and the hanger to it. Still using one of the ord or diy kits don't take much more. You do have to deal with the rivets to the stock hanger, but that's not a problem with a die grinder and air chisel. As far as sagging is concerned, since it uses stock springs if you have a sag already the shackle flip won't net the normal 4" of lift that it normally done. If you went with blocks instead of the flip you still wouldn't net the 4" it says.
#24 |
Ridin' Dirty
1978 C3500 Crewcab (Project) 1979 C2500 Crewcab (Driver/project) 1988 R2500 Crewcab (Driver) 1988 V3500 Crewcab 1988 R2500 Crewcab (Mint, Ex Fire Dept) 1968 Chev Suburban (4x4 conversion) LINK 1970 Chev C20 Suburban (driver/cruiser)LINK 2005 Impala (Incognito vehicle) 2004 Yukon XL Denali (Kid hauler) 1947 Case tractor Facebook Page(1000's of pictures of GM cars and trucks organized into albums) YouTube Channel |
#25 | |
thanks for all the great info. my factory springs did not sag at all. but i will probably just go with another full spring lift when i pull off the 6 inch one i have now. Shackle flip would be the only other thing i would consider. i bet ride quality is great with that setup and a nice set of springs up front. thanks again |
