Old 04-30-2010, 03:59 PM   #1
rbagley
rbagley's Avatar
Aux. tanks
I'm thinking about taking the tank out of my cab and running off of one of the two saddle tanks. They aren't hooked up now but I don't think it should be too tricky. Does anyone know if they came with sender units for the gauge or do you just have to guesstimate? I'll have to post a picture later on, but there are two valves on the floor by the handle for adjusting the seat. Anyone know why there are two? Thanks.
rbagley is offline   Reply With Quote
Old 04-30-2010, 04:37 PM   #2
dfwright
dfwright's Avatar
Re: Aux. tanks
Ours didn't have any sender units. We had a pair of saddle tanks. We'd usually run off one of the saddle tanks till it ran dry, switch to the other, run that dry, then go to the main tank, and fill 'em all up when that ran low
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 04-30-2010, 11:55 PM   #3
da-burb
"Ochre Ogre"
da-burb's Avatar
Re: Aux. tanks
the factory aux tank did come with a sending unit. They had a switch on the dash that looked like a normal headlight or wiper blade knob that switched the tank sending wires going to the gauge.
As far as the 2 handles. If they didn't have a 3 way switch for a main and 2 aux tanks it would take 2-2 way switches to run 3 tanks. my old camper truck had a single 3 way switch.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 05-01-2010, 12:15 AM   #4
El Jay
Gone to greener pastures
Re: Aux. tanks
I installed aftermarket saddle tanks on my '76 Jimmy years & years ago.
On my installation the two valves were: one for the fuel to the carburetor, and one for the return line back to the tank.
The aux. tanks had sending units, but the gauge wasn't real accurate because of the shape of the tanks. "E" did not indicate enough, though.
Like dfwright, we'd run the aux tanks until we got an engine sputter then do a quick switcheroo. When the main tank ran low, so did the wallet. It was like a 67 gal. fill up.
We also carried a couple extra inline fuel filters because we were scraping the bottom of the barrel, so to speak.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 05-01-2010, 12:40 AM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Aux. tanks
My Travel Tanks each have sending units; there is a three-position switch at the bottom of the dash to select the tank you want to go to the gauge.
And a single three-way valve on the floor to select the tank for fuel flow. No return line...
El Jay: 67 gallons? Holy crap... I thought mine was bad at just over 50.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 05-01-2010, 01:02 AM   #6
El Jay
Re: Aux. tanks
It had the optional 31 gal. main tank and I installed a pair of 18's.
The fuel didn't go out as fast as the bladder filled up, believe me.
Old 05-01-2010, 09:08 AM   #7
mrein3
mrein3's Avatar
Re: Aux. tanks
When I got my truck it had one saddle tank. The PO ran it until it was dry and switched on the fly. He claimed that way he always knew what was in there; either some or none.
I like to be a bit more in control of things so I purchased a sender and gauge kit from JC Whitney. Now I run my unlocked seat tank first because the saddle door has a lock on it.
My control valve is a three-way valve. I have seat, saddle, and one open position. A couple years ago I broke the pot metal handle on the valve and actually found a replacement in one of those hardware stores that has been there a million years and has everything you need.
I mounted the gauge knee-knocker style under the ignition.
If you are going with only saddle tanks I'd install some indication of how much fuel is in there.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
