Machinist
Heads up racing
My local track over the last couple of years has put together a couple heads up streetcar events... Typical stuff like 20 mile cruise, windows roll up and down, all glass , mufflers and insured.
The tire rule is killing me though. the rule reads • No Back halved, Tubbed or Mini Tubbed vehicle allowed So if you can fit it within your stock fender wells and it has a D.O.T. stamp on it your good...... even if i run a tire that fits into the stock fender well im tubbed so my truck is put into the outlaw class.....SOOOO Im thinking of putting the tubs back stock... The rule dosent say anything about the rearend being narrowed. get some wheels with the right offset and go racing.... Now to my question. what is the biggest tire we can fit in the stock fender well. the key word is "in" Im not putting a straight axle in the front.. LOL |
Re: Heads up racing
I had a 29.5 12.5 sportsman pro on a ten inch wheel.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
Re: Heads up racing
At one point, I had a set of Hoosier quick times in a p325/50r15 on a 10" wheel in the stock tubs on mine.
Chris 1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas 7.02 @ 95.8, 1.45 60' 1965 Chevy C10 LWB, 355 sbc, TH350, daily driver |
Re: Heads up racing
I'm runnin a 28x11.5 et drag on 15x10 wheel, 4" b/s. Chris.
its a work in progess. 71 c-10 lwb, in the middle of frame off restoration. 69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump. ![]() ![]() 7.807 @ 88.37mph 1.60 60FT 80 g-20 van, tow rig, cammed 305, th350, 10 bolt 88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's |
#5 | |
Re: Heads up racing
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs. Best time so far 11.8@XXXMPH Last edited by team39763; 04-27-2010 at 11:01 AM. |
#6 | |
mini truck racer
Re: Heads up racing
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
#7 | |
Machinist
Re: Heads up racing
#8 | |
mini truck racer
Re: Heads up racing
