04-25-2010, 09:26 PM | #1 |
Power Supply LT1 Conversion Question.
So I'm coming to the end of my LT1 conversion. I have a quick question though.
I built the LT1 harness to be completely standalone. Now the LT1 side has a central power post. My understanding of the 63 harness leads me to believe that if I go from the aux post on the modern side to the Horn Relay on the old side of things, all the original parts / namely the lights will have power as required. This is my new under hood electrical center. The small block off to the right is the positive block. I figure I need to run from there to the Horn Relay? The 4 prong connector is for the electric fans. - Brian
1963 Long Bed C10 - LT1/4L60E Swap in Progress. Blew up the straight six and happened to have the engine trans combo on hand already. 1995 Impala SS - LT1/T56 Combo. This is my 1st priority project. |
04-25-2010, 09:46 PM | #2 |
Re: Power Supply LT1 Conversion Question.
Yep,
The old truck is powered off the connection at the horn relay (except for the starter of course). TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
04-25-2010, 10:43 PM | #3 |
Yeah, my starter circuit is all new from the bed mounted battery and ford remote solenoid to the 'vette starter in the front.
Guess I was just looking to confirm where I'm running wire to. I suppose in the future I'll probably build a custom harness for the truck side of things too. Figure remote relays for headlights and all that but for now I just need it to run. - Brian
04-28-2010, 04:59 PM | #4 |
Where did you get the "positive block"? It looks similair to the one that Mad Electrical sells
65Gregg Blue long bed White TBSS 61 Impala “The two most important days in your life are the day you are born and the day you find out why.” Mark Twain |
05-01-2010, 11:28 AM | #5 |
Jegs. It even has a nice little cover that doesn't fit once you put 3, 4ga wires on there.
So if I run 12v from my block to the horn relay what do I do with the old external regulator? Do i ignore it because the regulator wires aren't connected anyway? - Brian
05-01-2010, 01:18 PM | #6 |
Resistance is Futile
Thats what I would do unless a circuit is junctioned across one of the terminals. If not, I would then proceed to unbolt it and throw it away.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
