Old 04-30-2010, 12:09 PM   #1
BADPURPLE70CHEVY
406 Powered
BADPURPLE70CHEVY's Avatar
Gauge problem? Bad oil pump? ???????
Got the 406 in my truck and it will scream, but oil pressure gauge registers around 5-10 pounds of pressure at idle. I used all good parts but am wondering if it could be the gauge. Got a white face sunpro gauge. When your cruising the pressure is up around 40-50. No engine noise but is it possible the new oil puimp could be bad? Or cheap oil pressure gauge?
70 GMC
68 c10
2002 silverado
72 4x4
BADPURPLE70CHEVY is offline   Reply With Quote
Old 04-30-2010, 12:27 PM   #2
cdowns
cdowns's Avatar
Re: Gauge problem? Bad oil pump? ???????
electric or mechanical?? if electric it could be bad battery,charging system or wire connections
Old 04-30-2010, 12:32 PM   #3
BADPURPLE70CHEVY
406 Powered
Mechanical......
70 GMC
68 c10
2002 silverado
72 4x4
Old 04-30-2010, 01:46 PM   #4
Leviticus
Shake and Bake!
Leviticus's Avatar
What is your idle set at? My 350 will push about 22-28 psi at idle, 50 psi at cruise and 60 at wot. If your idle is set really low it could be giving you your low numbers.
I have my idle set at about 850 rpm's in park and that puts me at about 650 rpm's in gear.
Unless you have a leak in your gauge line, these mechanical gauges are pretty close to right. Also, I have never been one of those guys that has been a big believer in synthetic oils except in my diesel trucks. But odd as it is I gained about 5-8 psi at idle when I switched to a good syn...who knows?
"All tyranny needs to gain a foothold is for people of good conscience to remain silent."
Thomas Jefferson
"You are remembered for the rules you break."
General Douglas MacArthur
"Support Our Troops And The NRA"
Leviticus is offline   Reply With Quote
Old 04-30-2010, 02:44 PM   #5
BADPURPLE70CHEVY
406 Powered
My oil pressure is way lower so i gotta do some diggin into it to find the problem.
70 GMC
68 c10
2002 silverado
72 4x4
Old 05-02-2010, 03:31 PM   #6
junkyardjohn
junkyardjohn's Avatar
A GOOD RULE OF THUMB IS 10 LBS OF OIL PRESSURE FOR EVERY 1000 RPMS.(BIG DIFFERENCE BETWEEN 5 & 10 lbs AT 1000 RPMS) I'VE HAD THAT SAME PROBLEM A TIME OR TWO. AFTER YOU RULE OUT THE GAUGE & PULL THE OIL PAN TO CHECK THE OIL PUMP,(A REAL PAIN.. BUT POSSIBLE) PULL A COUPLE OF MAIN CAPS & LOOK AT YOUR BEARINGS. IF THERES ANY COPPER SHOWING OR YOUR CRANK JOURNALS ARE GROOVED OR THE FINISH DOESN'T LOOK POLISHED, PULL IT IMMEDIATLY & FIX IT. IF YOU DO.. DON'T FORGET TO SWAB OUT & CLEAN THE OIL GALLYS OR YOU WILL BE DOING IT AGAIN IN ANOTHER 2000 MILES. DON'T ASK HOW I KNOW. LETS JUST SAY ALL THOSE LITTLE BEARING PARTICULS HAVE TO GO SOMEWHERE. I LIKE TO USE A SHOTGUN OR RIFLE CLEANING ROD WITH A BRONZE BRUSH ON IT. I ALWAYS HOPE FOR THE BEST & EXPECT THE WORST.
GOOD LUCK WITH IT. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 05-02-2010, 03:48 PM   #7
BADPURPLE70CHEVY
406 Powered
Thanks. I hope its just a bad gauge because everything is brand new. Anyone ever had a bad gauge even though it was new?
70 GMC
68 c10
2002 silverado
72 4x4
Old 05-02-2010, 04:24 PM   #8
bigguy69
dazed and confused
bigguy69's Avatar
yep. mine came from advance. sunpro i think. it was swapped for another set
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 05-02-2010, 04:27 PM   #9
junkyardjohn
Originally Posted by badpurple70chevy View Post
thanks. I hope its just a bad gauge because everything is brand new. Anyone ever had a bad gauge even though it was new?
i never have.. But i always check it first, & look for a kink in the line... But i've never been that lucky. (it only takes about 5 min.) i have a 454 crankshaft that i welded to a 8"rally & the other end to a 6" vice. It serves as a daily reminder not to trust anybodys word on motor work. High dollar vice stand that i've had for over 20 years. As you probably know.. The price of admission is very expensive to this hot rod hobby. Good luck bud. Hope its something small & cheap. John
junkyardjohn
DON'T RENT U-HAUL
Old 05-02-2010, 04:32 PM   #10
Hubscrub
Cruzin
Hubscrub's Avatar
My 383 in my nova has always run oil pressure about the same numbers as you are running since it was built (me and dad built it) dad said that a sbc motor does fine at 5lb pressure idle and 30lb pressure going down the road thats fine (he was a mechanic for 30+ years and dirt track raced for years) so i trust his judgement, not saying your 406 is the same but just saying so maybe to sure your mind alittle
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 05-02-2010, 04:42 PM   #11
BADPURPLE70CHEVY
406 Powered
Was it the oil gauge? What did it do?
70 GMC
68 c10
2002 silverado
72 4x4
Old 05-02-2010, 04:43 PM   #12
BADPURPLE70CHEVY
406 Powered
copper line...no kinks...
70 GMC
68 c10
2002 silverado
72 4x4
Old 05-02-2010, 05:32 PM   #13
JDL
JDL's Avatar
what oil filter do you have
72 Chevy short step side with 454 air and tilt.
72 nova project car
63 chevy II drag car
Agency Iowa
JDL is offline   Reply With Quote
Old 05-02-2010, 05:42 PM   #14
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
What weight oil are you running? If you are running light oil the pressure will be lower. You lose a little power (less than 1%, so not much) running heavier but you will have more pressure. Of course this doesn't mean that you want to run the heaviest oil you can get, but I'd ask an engine builder that you trust what they recommend for your build. My engine builder recommended that I run 20-50 because of the summer heat we get (110+).
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 05-02-2010, 05:45 PM   #15
bigguy69
dazed and confused
bigguy69's Avatar
nothing. hooked up and nothing. i dont what was wrong with but the next was fine.
Old 05-02-2010, 05:52 PM   #16
BADPURPLE70CHEVY
406 Powered
Thought of that. running wix oil filter. Engine builder recommended 15/40 rotella. My brother runs 15/40 in a 700 h.p. dragcar with no problems. Might change the oil filter even though its new.
70 GMC
68 c10
2002 silverado
72 4x4
Old 05-02-2010, 08:12 PM   #17
truckdude239
truckdude239's Avatar
wix is a good filter dont think your problem is there your pressures sound normal to me 10 psui at idle and it should increase about 10 psi for every 1000 rpms
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 05-02-2010, 11:45 PM   #18
extd56
extd56's Avatar
Sounds Ok for me too, I have run motors with that oil pressure for a long time. AS long as the pressure goes up when you hit the throttle you should be fine. If the top end of your motor is not getting enough oil it will let you know when the rockers start to make noise.
extd56 is offline   Reply With Quote
