I'm a poor spectator
Re: Getting closer, You have got to check the new seats!
I have a few questions, what is the color of the wheels, it's not just a regular white is it? And did you use aftermarket trim?
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig ![]() 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! ![]() 1979 Ford F150 4x4 SWB Built Ford Tough!!! ![]() 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
![]() Join Date: Jan 2007
I don't know the name of the color but see the post above. I used NOS trim for all but two pieces but for the most part, the aftermarket trim is probably just as good from my experience. The only piece of aftermarket trim that was not that good was the tailgate trim, both of the top parts that fit into the center piece over the handle.
![]() Join Date: May 2006
Got a Q? How was SMS on there delivery date, they quoted me 3-4 weeks. Is the material a good match to the original?
Your seats look great, actually, your whole truck looks great...nice job!
#4 | |
My fabric from them came fairly fast but they got the order wrong and it took them 3 tries and a couple months to fix what was a pretty simple request. The fabric I eventually received was a perfect match.
1969 Chevy Custom Camper 3/4 ton Rust free survivor 1972 Chevy Blazer CST 4x4 Almost Rust free survivor 1972 GMC Jimmy 2wd Undergoing surgery |
Delivery was OK, I can't remember so it was probably ok time wise. The match was great, I would say about 90% perfect. The ribbed pattern did the correct thing but the pattern was a bit wider than the original but it fit ok on the utility buckets so you could not really tell. The biggest thing about the pattern was that as you remember was the fact that the pattern across the back was ok for the back but there was not a just plain straight ribbed pattern for the seat bottoms. Originally the pattern started in the middle of the back and went straight down to the bottom and over the front edge of the seat and down without repeating the middle back pattern. Sounds complicated but we had to repeat the design at the middle back on the seat bottom also, which really turned out OK but it was not a perfect 100% match. I also did not match the plain ribbed pattern on the back of the rear seat only because I failed to send them a picture of it. I just know they sent me several samples that were not correct and insisted that this was all they had. I never take the first 5 no's for the answer so someone mentioned a guy there name of Doug (I think) and I contacted him by phone, emailed a pic of what I needed to his personal e addy and he located it, and sent me pics to confirm. Once that all was done, it was a piece of cake, just $75 a yard! But when I got it, you could tell it was old school stuff, on the shelf a long time but it was ok strength wise according to the little upohlstry girl.
