Easy Does It
roof panel replacement question?
I want to swap my roof top panel, I found a good top from a junkyard, my question is if I need to drill all the way through the headliner panel also,or can I just drill out enough until the top seperates? I did not want to have to fill any unessessary holes on the underside of the roof top. any body got some good pics. of this? thanks
Senior Enthusiast
Re: roof panel replacement question?
Here are a couple of earlier threads on the topic that might help you out:
http://67-72chevytrucks.com/vboard/s...ght=roof+panel http://www.chevytalk.org/fusionbb/sh...hp?tid/239755/
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
Easy Does It
thanks for the threads!!
The cap can be removed entirely from the outside by drilling out the spot-welds around the perimeter of the drip rail. When installing the donor roof cap, the holes can be puddle-welded and the drip rail partially filled with flowable seam fill, therefore there is no evidence of replacing the cap from inside the cab.
