Old 01-04-2010, 09:18 PM   #51
srea76
srea76's Avatar
Re: Tail light fuel filler
classic parts have leds for 30 each. are those trash?
srea76 is offline   Reply With Quote
Old 01-04-2010, 11:53 PM   #52
HuggerCST
HuggerCST's Avatar
Originally Posted by 72 Long View Post
Nice work - very clean! At the moment, I'm contemplating the same type of filler mod. Torn between bed and taillight fill. I noticed what I thought was a tank vent hose in one of your pics under the bed. Where did you vent it? I looked at the marine filler and didn't see a vent. Also, did you run into any problems with the mechanical fuel pump after relocating the tank?
I drilled and tapped a hole in the side of the marine filler and installed a 1/8" pipe elbow, then ran a 3/8" rubber hose from there to the top of the tank. I don't know if it was needed, because the tank is vented elsewhere, but I didn't want any problems filling. The only filling problem that I have had is when it gets full it burps out fuel if you have the nozzle wide open.
The fuel pump is working fine, but it has lost prime after it sits a couple of weeks without running. I have considered adding a helper pump, but haven't done it yet, because it's only happened a couple of times.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 02-06-2010, 11:56 PM   #53
HuggerCST
HuggerCST's Avatar
I didn't want to take over DAVE67's thread, so I thought that I would bring this one back to the top to answer some questions that people had. The info & pics on the previous pages should answer most of them, and to answer the question about selling the design, if I thought that anyone would be interested, I would! I am making a pattern though, and will come up with something soon for those that are interested in one. (even if it's just a pattern) I'll post on the parts board when I get to that point.
I'll add a few pics to this thread soon too.
Wynne
Build thread
53 Chevy shortbed
69 Camaro
Old 02-07-2010, 03:45 AM   #54
68custom396
that looks great! I like how the filler tube goes up to the top of the light. i did this to my 72 in 2000 for my senior metal trades test, i used a hidden spring loaded cabinet hinge that part worked good, but the filler tube was down at the bottom of the light so when it got full of gas it would usually run back out.
68custom396 is offline   Reply With Quote
Old 02-07-2010, 10:14 AM   #55
Dave67
Junior Member
Dave67's Avatar
LOL!!!
You can take over my thread anytime, HuggerCST. your thread is where my idea came from
67 C-20 LWB
56 Nomad--- nope, sold it
75 Stingray
13 Silverado crew cab
08 Trailblazer (wife's)
Pittsburgh, PA
Dave67 is offline   Reply With Quote
Old 02-11-2010, 11:31 AM   #56
67_ShortFleet
67_ShortFleet's Avatar
I got the visa ready.
67_ShortFleet is offline   Reply With Quote
Old 02-11-2010, 11:41 AM   #57
srea76
srea76's Avatar
I would like one of those guts also to weld in there so I can get mine ready
Old 02-11-2010, 08:23 PM   #58
ChiefThinElk
ChiefThinElk's Avatar
Nice job HuggerCST, I like it, there wasn't very much room to work, huh?
ChiefThinElk is offline   Reply With Quote
Old 03-29-2010, 05:06 PM   #59
danw210
69 K20
I am interested in the pattern, plate or whatever you are coming up with. This mod is a must for me, looking to get started on it soon. Thanks HuggerCST!
danw210 is offline   Reply With Quote
Old 03-30-2010, 10:31 AM   #60
red70
I would buy a template or actual piece or whatever today if you were selling this now.
red70 is offline   Reply With Quote
Old 03-30-2010, 05:49 PM   #61
yfs200p
yfs200p's Avatar
That looks awesome, and so much cleaner than having a filler inside the bed. Nice work! Just a thought.... any chance of the tail light shorting out (possibly making a spark) and making the whole truck go kaboom?? I guess thats prob why you used the LED with wires tucked away...
'72 K10 SWB Fleetside. Avocado Highlander Frame Off Re-Creation
'72 K5 CST Highlander Project
'24 2500HD Z71 LTZ Duramax
'22 Tahoe Premier Duramax
‘03 2500HD ECSB 6.0L
yfs200p is offline   Reply With Quote
Old 03-30-2010, 09:26 PM   #62
RaceAGMC
RaceAGMC's Avatar
Another one interested in buying a piece or template as well. This is def the route i want to go. Hugger...please keep us posted.
70 CST, 6.0/ 4L80E in the works.
*Custom harness by 68 Short Step*
RaceAGMC is offline   Reply With Quote
Old 03-30-2010, 11:41 PM   #63
HuggerCST
HuggerCST's Avatar
Thanks guys, I'm working on it as I have time.
There's always a chance of that, but I think that it's actually safer than most side marker fillers because the cap is not vented, so no fumes there unless the cap is off, and no spark unless the lights are on. The LED lights help too, so I think you'd have to really screw up to cause a fire.
Wynne
Build thread
53 Chevy shortbed
69 Camaro
Old 05-03-2010, 05:45 PM   #64
RaceAGMC
RaceAGMC's Avatar
Is there any to get dimensions on this piece or some kind of sketch so i can make one?
Old 05-03-2010, 06:07 PM   #65
Mrrilla
Mrrilla's Avatar
Heres mine, LED tailights and a spring loaded hinge. Works good but it can be a little slow when fueling. I also ran into one pump that had the big plastic cup on the nozzle and I couldn't get the nozzle in.
1970 C10 SWB, 67 front clip, 3/5 drop, 350 TPI/700R4, Fiberglass tonneau cover, lots of body mods and.....a ford seat
Mrrilla is offline   Reply With Quote
Old 05-04-2010, 04:24 PM   #66
RaceAGMC
RaceAGMC's Avatar
Do you think it would be better if the neck wasn't almost flat in the bucket, maybe that would make is easier to get the nozzle in there?
Still looking for any kind of drawing with dimensions on it so i can mock mine up and take it to a shop and have it fabbed up.
Old 05-04-2010, 10:34 PM   #67
tim21391
tim21391's Avatar
i love it
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 05-12-2010, 02:03 AM   #68
FIREBALL
(007) aka Houdini
FIREBALL's Avatar
Ow man I luv this filler mod. So is there any chance of a templete or a how too on this? ....I luv the gas filler in the taillight idea...I'm not diggin the fume smell in the pickup (not to mention im not keen on the tank behind the seat anyhow ..lol) and I really didnt want to cut a hole in the bed floor either (not that most i've seen looked awesome)..... I'ts just not something I want to do i'd rather try this style mod plus reminds me of my grandfather's 56 as well.
Live life one day at a time!
FIREBALL is offline   Reply With Quote
Old 05-12-2010, 04:07 AM   #69
The_BullDog
The_BullDog's Avatar
very nice bro!
The_BullDog is offline   Reply With Quote
Old 08-14-2010, 12:01 PM   #70
RaceAGMC
RaceAGMC's Avatar
Any updates on this? Template or design for the rest of us wanting to do this mod?
Old 08-14-2010, 03:58 PM   #71
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I just cut out all my taillight guts so if ya got something ready to go I m ready if not I m thinkin I could build my own...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 10-19-2010, 11:20 AM   #72
lowbuck72
lowbuck72's Avatar
looks good.. templates???
lowbuck72 is offline   Reply With Quote
Old 10-22-2010, 04:39 PM   #73
ralphie628
x2
ralphie628 is offline   Reply With Quote
Old 10-22-2010, 11:46 PM   #74
HuggerCST
HuggerCST's Avatar
I'm slow, but believe it or not, I am working on it when I can.
Wynne
Build thread
53 Chevy shortbed
69 Camaro
Old 10-24-2010, 12:21 AM   #75
WIDESIDE72
WIDESIDE72's Avatar
Nice!
WIDESIDE72 is offline   Reply With Quote
