Old 05-03-2010, 10:27 PM   #1
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: want to cut springs have ???'s
tried napa and they cant get it reasonably ($65) and orielly autozone etc autmatically says 'no'
John
1999 Toyota Tacoma 4x4
Old 05-03-2010, 10:33 PM   #2
Hubscrub
Cruzin
Hubscrub's Avatar
believe it or not the rear springs on my wife's 67 are cut, and my buddy did it to his a couple years ago so it can be done
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 05-03-2010, 11:53 PM   #3
Leviticus
Shake and Bake!
Leviticus's Avatar
Dude, that is highly ghetto dangerous! Please to the original poster, do not cut your rear springs!
The fronts are easy, pull them and take a cutoff wheel and cut one full coil off. Slap em back in and go cruise. Check to see if your stock shocks are going to bottom out or not as well.
Some guys cut 1.5 coilsoff and say they have not had any issues, but they come out easy so start with one coil and see how you like it. You can always cut more off, but once it is cut...its cut.
To tell you the truth, my truck feels better in the front after shortening my springs. But that may just be me.
"All tyranny needs to gain a foothold is for people of good conscience to remain silent."
Thomas Jefferson
"You are remembered for the rules you break."
General Douglas MacArthur
"Support Our Troops And The NRA"
Leviticus is offline   Reply With Quote
Old 05-03-2010, 11:54 PM   #4
leddzepp
Moderator
leddzepp's Avatar
WOW....My rear end is puckering just looking at that.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 05-04-2010, 12:17 AM   #5
C/10 King
C/10 King's Avatar
C/10 Rene
1966 Short Fleet "The Hag"
1967 CST Short Fleet "Dark Poly"
1971 Short Fleet
1970 Jimmy Custom 2 WD "Golden Ticket"
1972 Blazer 2 WD "Retro Blaze"
C/10 King is offline   Reply With Quote
Old 05-04-2010, 09:49 PM   #6
Hubscrub
Cruzin
Hubscrub's Avatar
just to say:i agree on it not being the best way of doing it cutting the rears, we plan to buy her a quality lowering kit, the truck is not being drove now anyways i have the doghouse off it and rebuilding the motor that is just some of the crazy stuff the owners before me did to this poor truck
Proverbs 3:5,6
Old 05-04-2010, 10:24 PM   #7
Leviticus
Shake and Bake!
Leviticus's Avatar
Hey I'm not trying to give you a hard time, back in the day I did some mods that were highly questionable Hell I had a custom built 107ci chopper that I had so low that you really couldn't lean without dragging the forward controls down the road, not safe,but it sure looked badass!
I just want to make sure if we have a member that doesn't have a lot of experience with these trucks to go start cutting up his rear coils cause someone else did it. Like some said above, maybe you wouldn't see any problems with it that way, but I just want to give the safest, soundest advice I can.
Thomas Jefferson
Old 05-04-2010, 10:33 PM   #8
Hubscrub
Cruzin
Hubscrub's Avatar
no problem no harm taken i want the truck to be as safe as possible for my wife and i because you can buy replacement truck parts but you can't buy a replacement for her or her body
Proverbs 3:5,6
Old 05-12-2010, 06:05 PM   #9
junkyardjohn
junkyardjohn's Avatar
THE REAR COILS OFF OF A LATE 70s EL-CAMINO BOLT UP, & GIVE YOU 3 OR 4" OF DROP. NO PROBLEM CUTTING ONE COIL OFF THE FRONT. JUST MAKE SURE TO USE A CUTOFF WHEEL & DON'T GET EM HOT. FOR GODS SAKE.... DON'T CUT THE REAR COILS NO MATTER WHO SAYS IT'S O-K. IT'S NOT. & DON'T TAKE A TORCH TO EM EITHER. IF YOU WANT TO KILL YOURSELF... H@LL ... I WONT GET IN YOUR WAY, BUT THE PUBLIC ROADS ARE JUST FULL OF INNOCENT PEOPLE THAT MAY NOT WANT TO GO WITH YOU. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 05-12-2010, 06:13 PM   #10
junkyardjohn
YEP.. CAN'T BUY EM.. BUT YOU CAN RENT EM. JOHN (JUST A FEEBLE ATTEMPT AT HUMOR...... LIGHTEN UP)
junkyardjohn
DON'T RENT U-HAUL
Old 05-04-2010, 10:50 PM   #11
chev-obsession
chev-obsession's Avatar
I'd say around $50-$65 is reasonable. I had to get stock ones made at a shop locally. The receipt is gone now, but it was just a dollar or two shy of $60. It would probably be cheaper to do that than to get the nuts washers and bolts through lmc.
1965 c/10 swb
1969 c/10 lwb
chev-obsession is offline   Reply With Quote
Old 05-04-2010, 10:53 PM   #12
Leviticus
Shake and Bake!
Leviticus's Avatar
I'd check to see if you have a Big Rig shop near you, I had a Big Rig alignment/spring shop make mine for $20.
Thomas Jefferson
