Old 05-04-2010, 02:30 PM   #1
jackyl9999
jackyl9999's Avatar
WTB- Coy Wheel center cap spacers
WTB- A pair of aluminum spacers for the center cap on a Coy C-5 wheels. I have seen several sets that have been made on the board. I have tried to get some made locally with no luck. So if you have a extra set let me know.
Thanks,
Steve
1970 Gmc Grande Sierra Swb 2wd LSX (LQ4/4L80e)
1990 K1500 Daily
jackyl9999 is offline   Reply With Quote
Old 05-04-2010, 06:17 PM   #2
Tim R
Re: WTB- Coy Wheel center cap spacers
Put me on that list too. I need a set for my front wheels also
Tim R is offline   Reply With Quote
Old 05-04-2010, 06:23 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
I'll get on the list and I don't even have a set of Coys,... yet.
Keith
Convert to disc brakes.
Old 05-06-2010, 12:36 PM   #4
jackyl9999
jackyl9999's Avatar
Ttt
1990 K1500 Daily
Old 05-07-2010, 02:08 PM   #5
jackyl9999
jackyl9999's Avatar
ttt
1990 K1500 Daily
Old 05-07-2010, 02:53 PM   #6
fatboys69
fatboys69's Avatar
Guys if i still worked at my previous employer i could hook you up.
I made the 1st set and have the cad file if anyone needs it.
just shoot me an email
fatboysrodshop@gmail.com
fatboys69 is offline   Reply With Quote
Old 05-07-2010, 07:09 PM   #7
mcbassin
Still Learning
mcbassin's Avatar
I have access to CNC machines. I would like to see the cad file and might consider making these for board members if material and shipping is covered.
I have made many parts for members and like to help out when I can. Usually, the biggest problem is finding the time.
Old 05-07-2010, 07:44 PM   #8
lolife99
lolife99's Avatar
I would be interested in purchasing two of these spacers,... if the price is right.
Keith
Old 05-07-2010, 10:50 PM   #9
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Me too.
Zoomin is offline   Reply With Quote
Old 05-08-2010, 04:37 PM   #10
mcbassin
Still Learning
mcbassin's Avatar
I need a drawing or sketch with dimensions and tolerances
Old 05-08-2010, 08:08 PM   #11
lolife99
lolife99's Avatar
WIll the "cad file" from fatboys69 work?
Keith
Old 05-09-2010, 08:51 PM   #12
jackyl9999
jackyl9999's Avatar
Looks like the interest is there for someone willing to make a batch. I'm first in line!
1990 K1500 Daily
Old 05-09-2010, 11:10 PM   #13
mcbassin
Still Learning
mcbassin's Avatar
I sent him an email to get the cad file from him.
Old 05-10-2010, 06:57 AM   #14
fatboys69
fatboys69's Avatar
mcbassin,
sent you the cad files for the spacers.
FATBOYS69
Old 05-10-2010, 07:54 AM   #15
mcbassin
Still Learning
mcbassin's Avatar
Okay, I got the file I will take a look at it when I get to work.
Old 05-10-2010, 09:30 AM   #16
mcbassin
Still Learning
mcbassin's Avatar
Does this look like what you are after?
Old 05-10-2010, 09:36 AM   #17
mcbassin
Still Learning
mcbassin's Avatar
I will make a quick program to see how long it will take to make them. It looks like we need .25" (1/4") x 4" X 4" ea. We need to find the cheapest place to buy the stock.
Old 05-10-2010, 11:27 AM   #18
skeeterbug
skeeterbug's Avatar
put me in for a pair as well pending on price and all.
'71 LWB c10-"WORK" in progress
385 ci 4 bolt (4.040 bore), scat 6.0" forged h beams,scat forged crank 3.750, speed pro 5cc flat top, clevite bearings, .039 head gaskets,comp xr288hr 110* 288/294adv. 236/242@.50 555/576 lift, pbm hyd roller lifters, chad spiers 215cc imp. heads , comp 1.6 roler rockers, comp magnum push rods, edelbrock victor jr. single plane intake p&p (1206 gasket matched), quickfuel 750R DP , th 350 trans, 5.14 gear, 3000 stall
2012 best 1/8- 7.70 @ 87mph 1.70 60' (lil better)
2013 best 7.39
2014 best-7.38
New for 2013-strange rear coilovers, headman 1-3/4 headers, 5.13 r&p, .060 aluminum bed floor, 15x14 holeshots w/ 31x18.5 hoosier dot pro's, 15x4 holeshots w/ 26x5.5 m/t skinnies and 200+#'s in body weight loss & 6 point cage
skeeterbug is offline   Reply With Quote
Old 05-10-2010, 03:23 PM   #19
fatboys69
fatboys69's Avatar
That be them ! I made 4 ( one for each wheel ) so that all wheels look the same, but I am just an*l like that. Made mine out of 1/4" aluminum, you will need to get longer mount screws as well. If I remember correctly I got #10-32 x 5/8 Socket Flat Head screws in Stainless steel.
Old 05-10-2010, 03:45 PM   #20
mcbassin
Still Learning
mcbassin's Avatar
So does this space the center cap out on the front to miss the spindle? Is it not noticeable when you look at it? I'm having a hard time understanding where/why you need them? I'm also looking at the Coys for my kids truck.
thanks
Old 05-10-2010, 04:07 PM   #21
mcbassin
Still Learning
mcbassin's Avatar
I did a quick simulation, it looks like about 6-10 minutes to cut them on the mill. Maybe quicker depending how rigid the setup turns out. I will need to make a quick fixture and after that all I need is material. I did find a place to order it online: here
Old 05-10-2010, 05:14 PM   #22
lolife99
lolife99's Avatar
What are you using for material?
I may have a source for 1/4" aluminum, in small scrap pieces.
How big would each piece need to be?
Keith
Old 05-10-2010, 06:12 PM   #23
mcbassin
Still Learning
mcbassin's Avatar
I was thinking 6061 alum. 4"X4"X.25" thick should be plenty. Let me know what you come up with.
Old 05-10-2010, 06:25 PM   #24
lolife99
lolife99's Avatar
Let me look tonight.
Keith
Old 05-10-2010, 10:15 PM   #25
Zoomin
Man of Mini-Talents
Zoomin's Avatar
thanks
The center caps contact the bearing cap as you tighten the lugs. If you're lucky, the caps will bulge and not break, but even so the gap looks bad.
