Old 05-02-2010, 07:35 PM   #1
bcj67chevy
402 BIG BLOCK
bcj67chevy's Avatar
How far is the master cylinder pushrod supposed to stick out.
I just bought this 72' truck a couple weeks ago. Truck has power brakes. The brake pedal is very hard all the time(vac hose was hooked up to booster before). The master cylinder looked like crap so i took it off and the rod seems to stick out very far.
Currently it sticks out 1 1/4" past the mc mounting surface.
Anybody know how far it is supposed to stick out??
I'm not sure if this is the reason why my brake are crappy or not.
guys
1967 C10 swb
1970 GMC Jimmy 4x4
2005 Chevy tahoe Z71
2001 Chevy impala
bcj67chevy is offline   Reply With Quote
Old 05-02-2010, 07:41 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: How far is the master cylinder pushrod supposed to stick out.
It sounds like your booster needs replacing....IE no vacuum assist. That rod sticking out should be easy to push in and out by hand.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 05-02-2010, 08:08 PM   #3
bcj67chevy
402 BIG BLOCK
bcj67chevy's Avatar
the rod is in all the way right now. the rod comes out easy from the booster.
For where the rod is now, that would mean that the mc would be pushed in over 1 1/2" to begin with, is this right?
1967 C10 swb
1970 GMC Jimmy 4x4
2001 Chevy impala
Old 05-02-2010, 08:13 PM   #4
truckdude239
truckdude239's Avatar
nt really there is a hole int he back of the mc the rod slides down in
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 05-02-2010, 08:14 PM   #5
truckdude239
wooooo wooooo wooooo is the vacuumm line for the brake booster hooked tot eh vavle cover?????? if it is that not getting you the vaccum for the booster
David fuller
2000 Tahoe 5.3l 378
Old 05-02-2010, 08:18 PM   #6
bcj67chevy
402 BIG BLOCK
bcj67chevy's Avatar
no, that tube on the valve cover goes to the breather.
1967 C10 swb
1970 GMC Jimmy 4x4
2001 Chevy impala
Old 05-02-2010, 08:31 PM   #7
bcj67chevy
402 BIG BLOCK
bcj67chevy's Avatar
I see the hole now, thanks.
1967 C10 swb
1970 GMC Jimmy 4x4
2001 Chevy impala
Old 05-04-2010, 01:40 PM   #8
truckdude239
okay i was wondering it looked alot it it was was just checking
David fuller
2000 Tahoe 5.3l 378
Old 05-04-2010, 01:47 PM   #9
kcjones
I wish I was a cowboy
kcjones's Avatar
If it helps, 3/4T and 1/2T brake equipment is different...including master cyl rod lengths, etc.
-Kris
Met list: Cyclone,Wilson,TranzAm,extd56,hotrodhomi,mnky30,Rokcrln,Brad,JerryJones(well, his truck anyway).
kcjones is offline   Reply With Quote
Old 05-04-2010, 06:11 PM   #10
mclairmo
Push rod looks ok to me, just like mine. Just make sure that the hole in the master cylinder piston is the same length as your push rod so that the push rod just almost bottoms out in the hole but does NOT bottom out. Make sure booster is hooked up to full manifold vacuum like at the intake or the baseplate of the carb. May want to use a Mity Vac and make sure that the booster is not leaking. Autozone has replacements for about $100.
mclairmo is offline   Reply With Quote
