Old 05-04-2010, 05:57 AM   #1
Rushwater
Will or can I make 15 inch wheels fit an 8 lug Dana 60 and 14 bolt
I need help determining if 15x10 wheels will be able to fit over the the calipers and drums of a Dana 60 front and a 14 Bolt ff rear. The axles are going under my 1991 1/2 ton Suburban 4x4. I already have a new set of the tires I want to use and they are 15 inch. I like the old school look also. If any one has any information for me I would greatly appreciate it.
Rushwater is offline   Reply With Quote
Old 05-04-2010, 06:13 AM   #2
LONGHAIR
Re: Will or can I make 15 inch wheels fit an 8 lug Dana 60 and 14 bolt
It all depends upon the back-spacing of the wheels. Some will work, some will not.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 05-04-2010, 07:52 AM   #3
b454rat
I had 15x8s with 4 1/4" offset, had to grind the calipers down, but not hard to do, just timing consuming. The less b/s, less grinding.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 05-04-2010, 08:43 AM   #4
propanemudtruck
Local Redneck Authority
propanemudtruck's Avatar
But if you get to little backspacing you may run into increased wear on your bearings and ball joints due to leverage. I'd rather do a little grinding and keep the wheels tucked close. Just be careful on the type of weights used to balance the tires too.
propanemudtruck is offline   Reply With Quote
Old 05-04-2010, 09:33 AM   #5
LANDC
LANDC's Avatar
I ground my d60 calipers to aceppt a 15 inch rim and regret it somewhat now. I don't think modifying a brake component would pass an inspection if the inspector was anal. I know its a pain in the ass but before you do something irreversible look into the rules and regs in your area. Very worst case scenario : You are in an accident, and upon inspection they find you have modifyed your brakes and find you at fault because of said mod. Just my .02 cents.
Custom Vehicle, Custom Problems.
LANDC is offline   Reply With Quote
Old 05-04-2010, 02:39 PM   #6
ghettoluxury
ghettoluxury's Avatar
Lots of grinding is required or you can shell out the $200 like I did and order brackets from Sumner Machine Works that allows you to run calipers from a Dana 44. Then the only grinding that needs to be done is the casting flash. They will slide on the 14 bolt just fine.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 05-04-2010, 06:59 PM   #7
Quackaddict
"Hooked on Quack"
Very informative, I have a 3/4 ton with the 8 lug Dana 44 up front and 14bolt in the rear and thought I could only go down to 16's. It is hard around here anyways to find a 15" rim in 8 lug but if a deal comes along good to know I can get them on the truck.
Semper Fi,
Kevin
USMC
Quackaddict is offline   Reply With Quote
