Old 05-04-2010, 01:25 PM   #1
burke117
Header Gaskets????
What type of header gasket is the best to run on a 350? I know they sell several different material types of gaskets, I want to buy one that I wont have to replace over and over. Any suggestions???
burke117 is offline   Reply With Quote
Old 05-04-2010, 01:53 PM   #2
kcjones
I wish I was a cowboy
kcjones's Avatar
Re: Header Gaskets????
Check out this article. I'm living a nightmare of exhaust leaks...
http://www.chevyhiperformance.com/te...ets/index.html
-Kris
Met list: Cyclone,Wilson,TranzAm,extd56,hotrodhomi,mnky30,Rokcrln,Brad,JerryJones(well, his truck anyway).
kcjones is offline   Reply With Quote
Old 05-04-2010, 02:05 PM   #3
jgreene0717
Jason
jgreene0717's Avatar
If you are using the headers on a stock cast iron cylinder head I have had the best luck just using the stock manifold gaskets.
jgreene0717 is offline   Reply With Quote
Old 05-04-2010, 02:15 PM   #4
scott's69
WORTHLESS CRUISERS
scott's69's Avatar
Ive got headers on mine. The best and cheapest ive found is stock manifold gaskets from a ninetys model. Ive never had a leak and they are easy to get at any local parts store.
Scott Hammond
Lancaster, SC
1969 Chevy2005 Chevy Silverado Z71 72 Chevy 1972 SWB 454
If you don't live for something, then you'll die for nothing. www.xclusive-images.com
scott's69 is offline   Reply With Quote
Old 05-04-2010, 02:20 PM   #5
custom70
custom70's Avatar
I use the aluminium type and they work great, just be sure to recheck the torque after a couple of heat cycles unless you are using the locking type fasteners.
custom70 is offline   Reply With Quote
Old 05-04-2010, 05:47 PM   #6
burke117
what do I torque the bolts too?
Old 05-04-2010, 06:22 PM   #7
Bpokey
Bpokey's Avatar
I got some Mr Gasket ultra seal ones from oreillys for $12 and they seem to be working good.
Bpokey is offline   Reply With Quote
Old 05-04-2010, 06:24 PM   #8
custom70
custom70's Avatar
I don't know a certain torque value. Just nice and tight with a wrench by hand (don't try and break them off tight) and remember to recheck them.
Old 05-04-2010, 06:28 PM   #9
BADPURPLE70CHEVY
406 Powered
BADPURPLE70CHEVY's Avatar
I agree x2
70 GMC
68 c10
2002 silverado
72 4x4
BADPURPLE70CHEVY is offline   Reply With Quote
Old 05-04-2010, 06:34 PM   #10
BarryB
BarryB's Avatar
I have always had good luck just using the stoc replacement gaskets. I have doubled them up before also. I usually use some high temp gasket sealer in between them. The one I have the hardest time sealing in the flange at the bottom. I'm seriously considering the flow master weld on clamp together flanges.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 05-04-2010, 09:03 PM   #11
vectorit
What?
vectorit's Avatar
When I ran headers on the burb, I just used those white Mr Gasket gaskets.
Though what I did is soak them in a pan of water for a day or so, that way when I installed them they had a tiny bit of squish which when dried gave a better seal IMO. As for torque on the header bolts, I just used the German torque value of good n' tight.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
