05-01-2010, 08:23 PM | #1 |
Grandpa in the rustmobile...
Air leaking out of MC causing brakelight to come on
I have air comming out of the hole (all the way thru MC). I can cover it wiht my fingers to seal it up. It used to not come out of this hole. It causes my brakelight to come on, and brakes to be really hard to push down. What do I do to fix it and why is it doing it? Thanks!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
05-01-2010, 08:26 PM | #2 |
laying low
Re: Air leaking out of MC causing brakelight to come on
Your brake booster has gone bad. Replacement is necessary.
05-01-2010, 08:36 PM | #3 |
Really?!
crap, oh well it IS 40 years old
05-02-2010, 05:24 AM | #4 |
Bad booster, Autozone has replacements for about $100.
05-02-2010, 09:09 AM | #5 |
a leak is a bad booster but i think theres additional problem with master cylinder causing the light to go on // i'd change both and while at it go over the whole brake system to tune it up to specs// the factory service manual has excellent info on the proper procedure to bleed the brakes for proper operation
05-02-2010, 11:38 AM | #6 |
Kid's Mechanic
There is a rubber seal that fits over the rod that pushes the master cly.and and fills the recess in the booster,Is that missing? Noticed fresh paint on the booster and i'm wondering if its pinched or fell out?
If you go the rebuilt/new booster don't be surprised if the master cylinder comes with it .Some re-builders won't sell one with out the other Last edited by powerdriver 1958; 05-02-2010 at 11:41 AM. |
05-02-2010, 09:45 PM | #7 |
its a new MC, i just put new paint on the booster to make it look better.. I'll check it out tomorow after school...whats this seal look like.
I pretty much dont have power brakes on the truck, theres a little but they dont help much
05-02-2010, 10:23 PM | #8 |
so I need a new booster?
should I go with the gold finish or painted one?......
05-04-2010, 10:32 PM | #9 |
Can I rebuild it? Dad was thinking I could rebuild it for cheaper, if you can get parts even..
