Old 05-04-2010, 10:38 PM   #1
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Installed electric fans today!
how much extra hp does that free up looks nice good job!
John
1999 Toyota Tacoma 4x4
Old 05-05-2010, 07:35 PM   #2
70C10Toejam
Hellasick
70C10Toejam's Avatar
Thanks. Tried to make it look somewhat neat.
On here I've seen either 10-15hp or 10-15%, forget which one though. I wouldn't guarantee either of those numbers though
Also, running the factory 63 Amp alt. and at idle with low fans running, it still holds 14.1 volts. With lights on, it does drop to 12.8-13.0, enough to not actually drain the battery, but not enough to truly run the system. Have not forced the high speed on to see if it handles it at idle. Plan on doing the internal regulator swap to a 94 amp, hopefully later than sooner.
So far so good on keeping it cool, but only 67* out today.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes)
This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do.
RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!!
BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys
70C10Toejam is offline   Reply With Quote
