Old 05-06-2010, 02:41 AM   #1
NZSquare
NZSquare's Avatar
Gas tank options on a bagged 82 ?
Hi all,
Ive got a bagged 82 wrongbed c10 and just finished up the bridge etc out back (see pics). Its all worked well but my saddle tank is now too close to the deck for comfort so I want to go to the rear mount underbed type.
Im in New Zealand so shipping a performance online one isn't really an option (450 + 200 shipping) and they are 10 1/2 " deep.
Conditions are :
-fit within rails (26 x 22 x 8 deep approx)
-use factory fuel gauge.
Im open to suggestions, searching showed loads of guys putting mustang and burb ones in 67-72's and earlier, but what about the newer ones ?
Ive found RCI and summit fuel cells that fit but am not too keen on plastic.
Any suggestions are appreciated, right now I'm looking at having one made.
NZSquare is offline   Reply With Quote
Old 05-06-2010, 04:18 AM   #2
ripdog28
ripdog28's Avatar
Re: Gas tank options on a bagged 82 ?
Find a local who can weld Alum and have them fab one up. Just make the stock style fittings.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 05-06-2010, 08:11 AM   #3
andrewmp6
Yeah a good welder can copy the performance online one for you.
Old 05-06-2010, 03:21 PM   #4
AVS_JASON
AIRBAGPARTS.COM
AVS_JASON's Avatar
K5 Blazer tanks fit great. Thats what I have. Got one in great condition for under $100 at a junk yard.
AVS_JASON is offline   Reply With Quote
Old 05-06-2010, 04:03 PM   #5
NZSquare
NZSquare's Avatar
Thanks for the replies,
Having one made is an option, there are guys in town I would trust to do it but Id rather a semi stock looking one if that makes sense.
Jason, what depth are the blazer tanks ? Is that what your're running in your square body ? which I love by the way, the two tone rules.
Blair
Old 05-06-2010, 04:21 PM   #6
Daveboyd
Daveboyd's Avatar
Blair
We build custom tanks. check out our site and give me a call if your interested in a quote.
Dave Boyd
View Our 63-72 C10 Tank options https://fueltankparts.com/collections/63-72-c10-tanks
Boyd Welding Main Site : http://www.boydwelding.com/
Boyd Online Shop: https://fueltankparts.com/
E: Sales@boydwelding.com
Daveboyd is offline   Reply With Quote
Old 05-06-2010, 05:18 PM   #7
AVS_JASON
AIRBAGPARTS.COM
AVS_JASON's Avatar
Blair
Thanks dude.... Not too sure about the depth. It fitsperfect between the rails. Its was a new K5 that it came out of.
Old 05-07-2010, 09:16 AM   #8
andrewmp6
Just remember hes in aus shipping on anything will kill him.The k5 blazer tank 73-91 will work new is best but good luck finding a used one in aus.You could go to a junkyard and see what cars used a smaller tank you could rig up in the back of your truck.
Old 05-07-2010, 04:14 PM   #9
NZSquare
NZSquare's Avatar
I can get a blazer tank locally but Id like to keep the bed floor at the stock height if poss, I use it plenty for bikes and the like. Although I guess thought it wouldn't be that much work to raise the rear section a few inches.
With the blazer tank do most people run the filler on the floor of the deck or can you put it on the side on the inside ? I saw one of the 67-72's on here where the guy had a jeep filler on the inside, looked pretty slick.
The other option I was looking at are these summit ones http://www.summitracing.com/parts/SUM-290108/ , cheap and shipping is manageable, will these plastic ones deteriorate under the deck ?
Thanks again for the info.
Old 05-07-2010, 08:11 PM   #10
SBTork
Garage wrench
SBTork's Avatar
FYI....the tank dimensions are on LMC Truck's online catalog, http://www.lmctruck.com/icatalog/bzc/full.aspx?Page=123
looks like...
25 gallon : 28 3/4" x 21 1/8" x 10 3/4"
31 gallon : 28 3/4" x 21 1/8" x 12 3/4"
may help, may not....
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 05-08-2010, 01:37 AM   #11
andrewmp6
You can put the filler anywhere you like just have to run a gas safe tubing.
Old 05-08-2010, 09:32 PM   #12
GVizzle
GVizzle's Avatar
How many gallons is that 67-72 tank on your site?
GVizzle is offline   Reply With Quote
