Old 03-23-2010, 10:46 PM   #1
64GMCHorsepower
Justified!
What size sway bar works best?
I'm looking to get a front sway bar for my 64 GMC......
I see 7/8" , 1" and also 1 1/8"
Does it really make a huge difference in which one I get?
is one size better than the other?
Do I need a special one with my front-end being lowered 2"-3"......
Thanks for the help
Chad
1964 GMC Fleetside Shortbed....350/700R4 tranny
64GMCHorsepower is offline   Reply With Quote
Old 03-24-2010, 12:30 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: What size sway bar works best?
Any of them will work. The standard size on the 73-87 C-10 was 1", and the C-20's came with 1 1/8". I would go with the larger size if it's available.
The size of the bar doesn't matter if the truck is lowered or not. There are a couple of options available for mounting it. The stock bushing clamp "stands" are riveted to the frame. If your truck never had a sway bar it won't have the stands.
You can locate the stock stands, or buy a lower profile version from E.C.E. You can also bolt the clamps directly to the frame. This might work best if your truck was a bit lower, but should be alright as it is.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-24-2010, 08:23 PM   #3
64GMCHorsepower
Justified!
What do you mean by bolt the clamps directly to the frame? I thought the sway bars were always attached to the control arms?
Chad
Old 03-24-2010, 08:59 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
The other end...
Articles-
"Refining Sierra"
Old 05-06-2010, 11:57 PM   #5
Russ65C10
Russ65C10's Avatar
Bigger is better :-)
My 65 came stock with a 7/8 but I am in the process of replacing it with what I believe is a 1.25 inch off of a late 80's C30. The 7/8 just isn't enough bar for me especially with the 15/16th inch IROC Z28 bar I have on the rear.
Do your self a favor and just go down to your local pick-a-part and pull everything you need off of late 70's or early 80's 3/4 ton. That should get you the 1 1/8th bar, if you want a rear bar pull one off of 3rd gen Camaro. You shouldn't have to spend more than $30 - $35 per bar with all the mounting hardware. The Camaro bars mount up really nice on the back with the coils. Here an article on how to: http://www.low69cst.freeservers.com/CamaroBar.htm
Russ65C10 is offline   Reply With Quote
Old 05-07-2010, 12:09 AM   #6
mclairmo
That rear sway bar article is awesome. Thanks.
mclairmo is offline   Reply With Quote
