Old 05-18-2003, 11:22 AM   #1
83C
83C's Avatar
Question What is my axle ratio?
I own a 83 swb and from factory it came with a 250 I6 and a 3-speed with overdrive manual transmission. I am trying to figure out what gears I have in my rear axle. The only information I have is from the Service Parts Indentification card. The option # is GQ1 and the description is Rear Axle - Standard. Can anyone tell me if I can find out the ratio with this information? I am putting a 350 engine with a 700r4 transmission and I want to find out if I can use this rearend or not.
83 Chevy SWB
http://www.cardomain.com/id/letheridge
83C is offline   Reply With Quote
Old 05-18-2003, 12:18 PM   #2
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
For your 10703 model (short wheel base regular cab, C10) with the MM7 transmission (4 speed manual with overdrive) and LE3 (250-2bbl inline six) the GQ1 ratio corresponds to a 3.08:1 rear axle ratio.
The standard axle ratio with a 305 (350 wasn't available in a 2wd 1/2 ton) and a 700R4 was 2.73 to one, and 3.08 was an available option, so yes, those gears will work fine.
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '87 C10, '87 R30, 2 '89 R3500 Flatbeds
ElGracho is offline   Reply With Quote
Old 05-18-2003, 12:28 PM   #3
83C
83C's Avatar
Thanks for the information. Were did you find the information fot all those codes?
83 Chevy SWB
Old 05-18-2003, 12:58 PM   #4
ElGracho
ElGracho's Avatar
I used my 1983 Chevrolet Light Duty Models preliminary data book. It was used by dealers to get the codes to custom order vehicles and see what options were available with what etc... I have a few of them that I bought at swap meets and off Ebay. The RPO codes are also available on the internet, here is a good site.
keep in mind that you needed more than just the RPO codes to figure this one out.
Joe
Old 05-18-2003, 09:20 PM   #5
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Nice to see another '83 hitting the road again!! 700R4s rock!! I love mine. My 305 can beat them 255/60R15 tires with the 3.08 pretty good.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 05-18-2003, 10:51 PM   #6
r0lf-
Hotwheels?
r0lf-'s Avatar
My 250 /w 3 speed manual has 3.73's as the "standard axle"
but thats in '80 not 83
r0lf- is offline   Reply With Quote
Old 05-18-2003, 11:17 PM   #7
ElGracho
ElGracho's Avatar
Well, according to my 79 dealer sales album (I don't have any literature for 1980, KIILEW where are you?) 3.73 gears would only be available with a LE3 250 I6 with an MM3 3 speed standard trans in a half ton if it had the F44 (Big 10) heavy duty rear suspension. Even then, the GQ1 standard ratio was 3.07 and 3.73s were optional with code GT4.
This all depends on engine, trans, and GVW of the truck. Saying 1/2 or 3/4 ton isn't even close enough since there were various GVWs even between those.
Joe
Old 06-06-2003, 12:41 AM   #8
83C
83C's Avatar
I still can't figure out my axle ratio. I pulled the differential cover off to try to find out for sure what ratio I have. I found a set of numbers on the largest gears. 1 GM 1235124 15 41 3 83. I have heard that if you divide the middle numbers it will tell you the ratio. 41/15 equals 2.73. Is this my ratio?
83 Chevy SWB
Old 06-06-2003, 12:43 AM   #9
ElGracho
ElGracho's Avatar
Yep.
Joe
