05-08-2010, 05:19 PM | #1 |
Windshield Washer
Ok, it hasn't worked since I got the truck. I decided to get after a remedy. So today I replaced all the rubber lines (rotten) and pulled the washer. Let it soak with some vinegar. Previously the plunger was stuck and now it moves decent. Put it all back together. I have squirters. Cool. Only problem is they are squirting whenever the wipers are on even if I don't push on the switch. And they are squirting in time with the wipers. So I'm thinking bad switch. Thoughts? Anyone else experienced the same?
05-08-2010, 06:49 PM | #2 |
The Older Generation
Re: Windshield Washer
Could be but I would double check the wiring... LockDoc
05-08-2010, 10:07 PM | #3 |
check the spring inside the switch take it apart and push the spring flat then put it back in and try it. thats y mine was coming on all the time
