05-09-2010, 07:18 PM | #1 |
booster question
i have a half ton 70 gmc with drums all the way around and i picked up a booster to put on but it came off a 3/4 ton does this matter or are they all the same?
05-09-2010, 07:26 PM | #2 |
Re: booster question
They are not all the same, but should work fine.
05-09-2010, 07:33 PM | #3 |
Active Member
Make sure you also get the proportioning valve, the pedal pushrod asm from inside the cab.
