Old 05-04-2010, 01:29 AM   #1
DA INFERNO
DA INFERNO's Avatar
Uni-Ball Upper A-Arms
Does any one make Uni-Ball Upper A-Arms for our trucks? I would like to install a drop member with Uni-ball upper arms.
1964 CHEVY LB, 20" WHEELS, BAGGED
DA INFERNO is offline   Reply With Quote
Old 05-04-2010, 10:37 AM   #2
AVS_JASON
AIRBAGPARTS.COM
AVS_JASON's Avatar
Re: Uni-Ball Upper A-Arms
AVS_JASON is offline   Reply With Quote
Old 05-04-2010, 11:34 AM   #3
PBFAB.COM
PBFAB.COM's Avatar
I will happily build you a set with uniballs.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 05-04-2010, 11:54 AM   #4
SCOTI
SCOTI's Avatar
I'll bite . . .... Why the need?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-04-2010, 02:49 PM   #5
DA INFERNO
DA INFERNO's Avatar
I think they are a cleaner look.(no grease to drip down) I run them on my diesel truck and have never seen any on an older truck. Just wondering if they are any out there.
Old 05-04-2010, 06:43 PM   #6
cajundragger
Im going to be running uniballs on the uppers of my truck...
why?
-more travel than the typical Chrysler ball joint found in MMII front ends
-no rubber boot to tear
-whole unit is smaller than a ball joint so my control arm will be "thinner" where the bj is and hopefully wont hit the upper bellow on my bag and I can get more lift to untuck my 20's.
cajundragger is offline   Reply With Quote
Old 05-04-2010, 06:54 PM   #7
SCOTI
SCOTI's Avatar
You guys aren't concerned w/dirt entering the contact surfaces causing wear?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-04-2010, 08:10 PM   #8
DA INFERNO
DA INFERNO's Avatar
They use them on Pre-runners in the sand. I use mine in Pismo and have had no problems.
Old 05-04-2010, 08:59 PM   #9
shortbed70
shortbed70's Avatar
OK my ? is how much?
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 05-04-2010, 09:01 PM   #10
dv8customs
dv8customs's Avatar
I think the Barely Legal Fab arms pictured above run around $1,100 for uppers and lowers.
dv8customs is offline   Reply With Quote
Old 05-04-2010, 10:19 PM   #11
DA INFERNO
DA INFERNO's Avatar
Any more pics of Uni-balls?
Old 05-05-2010, 01:33 AM   #12
cajundragger
uniballs themselves are like 60-80 bucks.
Old 05-09-2010, 07:04 PM   #13
orange71
Size:  10.5 KB Heres a set that i had built
orange71 is offline   Reply With Quote
Old 05-10-2010, 12:39 AM   #14
DA INFERNO
DA INFERNO's Avatar
Sounds like a plan.
