Old 05-10-2010, 08:25 PM   #1
sshockr
New brake lines?
Blew out a hardline and due to the amount of rust I'm thinking it's time to replace them all. I am not the best at bending tube and am under a bit of a time crunch now so I'm leaning toward pre-bents from LMC. Being in KC they should get here (Wichita) fairly quick. Quality product? Should I worry?
My other question is I'd really like to go to a dual master cylinder now in preparation for other upgrades down the road. Any particular mid 60's booster I should be looking for?
My other wonder is can I get a '95 GM full size car booster and MC to bolt in at the same time? I happen to have one of these sitting on my shelf in good working order. I know I'll need to bend a couple new lines mostly short ones in the front. And maybe a few straight couplers instead of tees.
Am I making sense at this point?
Gonna go play with the master cylinder now, and start removing old parts.
Stupid brakes. Had to cancel an appointment with the exhaust shop today cause I can't get the truck there.
Thanks for all the info and help.
- Brian
1963 Long Bed C10 - LT1/4L60E Swap in Progress. Blew up the straight six and happened to have the engine trans combo on hand already.
1995 Impala SS - LT1/T56 Combo. This is my 1st priority project.
sshockr is offline   Reply With Quote
Old 05-10-2010, 09:04 PM   #2
sshockr
Re: New brake lines?
Went out and measured. The booster bolt pattern is 3-3/8ths by 3-1/2 inches so CapitanFabs adapter should bolt right up.
Can I use a Steel plate to bolt from the MC to the Pedal? I figure something triangular from the pedal (2 corners) to the pushrod from the booster (1 corner) Its not threaded like the truck ones and already has an end on it that you could pass a bolt through.
Thoughts?
-Brian
