smc valves wtf!!!!!!
just got the front bags in and decided to check the valves, hooked an air hose up to them and they bleed back through the valves, there hooked up right, valves are new, wtf... i cant proceed on the valves, tanks and the pumps i dont get it hellllllllllllllllllllllllllllllppppppppppppppppppp.....
Re: smc valves wtf!!!!!!
Sounds like you were forcing air through the valve backwards which it will bleed through.
Also, if you dont have check valves and you have low or no tank pressure the bag pressure will bleed back into the tank until it equalizes.
It'd be alot cooler if you did
^^right on
On the fast track to nowhere..
Exactly. Most valves require a minimum pressure on the back side to keep the valve closed.
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
![]() Join Date: Sep 2007
where do you install the check valves then? just before the the fill valve?
1967custom |
I only used check valves when I ran Nitrogen(so I didn't have to lay the truck out to change the bottle). But yes, they would need to be before the fill valve. Once you get the tank and pumps installed they should be fine without check valves. I think the minimum PSI is only around 3-5 to hold the valves closed so as long as you keep that much in the tank they're fine. If you have Viair pumps they have a check valve built in to the leader.
Wide n'Low
![]() Join Date: Jan 2007
""If you have Viair pumps they have a check valve built in to the leader.""
I was just going to say the same thing..
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
nope, running a thomas (thompson?) pump no check valve but Im still building the system, so there shouldnt be any pressure backfeeding thru the valves if I have them plumbed right then correct?
1967custom |
low n' slo
![]() Join Date: Mar 2009
a new leader hose from suicidedoors comes with a built in check valve. thats what i bought..
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
Correct. Just put a check valve between the pump and tank and you should be good to go.
good deal, thanks, I didnt mean to steal the thread!!!!
1967custom |
Thanks guys i appreciate all the info>>>>>>>
