Burb or panel lower quarters...
Where can I find lower quarter skins for a panel or burb??
Or will the shortbed truck skins work?
Tim Road Hounds |
Re: Burb or panel lower quarters...
Yes, the lower bed panels will work with some work. Hemmit
Thanks D
Wheres the cheapest place to buy lower skins?
Tim Road Hounds |
I saw some lower quarter panels on Ebay. The guy had three. The ones for in front of the wheel wells and the drivers side rear. Wouldn't you know I need the passengers rear
I think to complete the regular panels at the bottoms, the addition of the cheaper weld in replacement rockers will give you that underneath bottom piece that goes under to meet up with the inner panels that the suburban or panel body uses. cut and weld to achieve it
ron |
When rebuilding my 66 Burb I couldn't find any repair panels so I had to buy a donor vehicle to cut up and weld on the donor panels. This is tooooo expensive solution to replace panels but it worked for me.
" I never think of the future. It comes soon enough " - Albert Einstein |
