![]() Join Date: Oct 2008
Motor mount question
Could somebody please tell me the difference between BB motor mounts and SB mounts.Both the perch and mounts.Thanks.
Re: Motor mount question
big block mounts have a dish that starts right off the frame rail down tothe motor mount the small blocks have a strait slope to the mount
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! Last edited by Willys47; 05-11-2010 at 09:46 AM. |
Can I use my BB towers with a SB?
I would think that you can cause I have heard of trucks with big blocks using small block mounts , but I havn't tried it to be sure.
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! |
![]() Join Date: Oct 2002
bb will not work on sb mounts unless you have shorty headers or get lucky with a certian brand header.I tried to put bb on sb stands and the exhaust manifolds hit the frame stands.same with 2 sets bb headers I had.I had to get correct bb stands.I had sb on bb stands and bb auto linkage on truck I bought with bb removed and sb installed.trans linkage was at an odd angle and wore a grove in the pivot pin. sb auto frame pivot pin may have corrected this with bb stands but I pulled it all and installed all correct sb stuff so don't know for sure on that. once I installed sb stands fan wanted to just lightly rub bottom of bb shroud and I put in correct sb shroud also.it did have aftermarket flex fan and this might have caused rub.
![]() Join Date: Aug 2001
yes you can.
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
