Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > Welcome Area
Old 05-08-2010, 12:36 PM   #1
gregg72340
gregg72340's Avatar
Hi, new to all of these trucks.
Hi, I just joined he board and am located in Philadelphia. I just bought a 68 GMC 292 1/2 ton longbed 2 wheel drive leaf spring truck that is in pretty good shape metal wise.
I Have a ton of questions that hopefully some f you folks can help me with.
I have an 82 GMC half ton parts truck at my disposal that I am trying to see what I can interchange with my 68. I would like to to take the dic brakes off the 82 what will I need to swap, I pretty much assume everything and use 82 style ball joints. Can I use the power steering box off of the 82? IS the rear axle the same dimension as the 68 and would I be able to bolt iit right in? Or is there another rear I could just bolt in. Eventually the 68 is going to have a 402 Big block bolted in so I need some sort of rear that will survive behind that and have a 5 bolt pattern.
Any help would be greatly appreciated
gregg72340 is offline   Reply With Quote
Old 05-08-2010, 10:58 PM   #2
jayman68
Fun Stuff
jayman68's Avatar
Re: Hi, new to all of these trucks.
Welcome from NW Washington. You will get a better response if you post your question in the suspension section.
I have a 68 Chevy, I used the complete cross member from a 78. I just had to redrill a couple of the side holes. I dont know if the 82 will be much different, but I don't think it would be a problem. Also the power steering gear box bolted right up. It made it pretty easy. Good luck with the project.
Jay
68 C10(project)
88 Honda Accord(DD)
93 Chevy Astro EXT 2wd
jayman68 is offline   Reply With Quote
Old 05-12-2010, 05:22 PM   #3
Liz
Catchy title goes here..
Liz's Avatar
Welcome to the site.
Liz is offline   Reply With Quote
