Old 05-19-2003, 06:52 PM   #1
mikegi
? on 400 small block
have a chance to buy a 400 small block out of a 72 caprice.the question is how do i tell if it is a 400 ( besides the #s on block)do 400s have 3 freez plugs? and the guy said it has a 2 barrel on it.must travel about 100 miles to get it ,just don't want to get there and find out it's a 307 (not that i have done that) lol.
Springvale,Maine
71 3/4 GMC lwb
mikegi is offline   Reply With Quote
Old 05-19-2003, 07:13 PM   #2
Eddie H.
Eddie H.'s Avatar
You can identify a sb 400 by the harmonic balancer with a counterweight on it. They were externally balanced, all other small blocks were internally balanced. All of them I've seen also have 3 freeze plugs on each side. If I remember correctly, they only came in 2 barrel versions.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 05-19-2003, 07:36 PM   #3
Blue_71
Bloo
Blue_71's Avatar
mine has 2 on each side and 2 on the front, and i have ran the numbers, its a 76 400
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 05-19-2003, 07:42 PM   #4
neonlarry
neonlarry's Avatar
I was just going to say the harmonic balancer but someone slipped in before me with that. That and the suffix code are the best, on a Caprice you should be able to see the # fairly easy.
When you get there though unless its really really cheap I'd pull the heads and check for cracks between the bores and also check the pistons to see if they are oversize and how much, .060 over is about the limit on a 400 unless you want to sleeve it. Good Luck I'm still looking for a good 400 block myself.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 05-19-2003, 08:06 PM   #5
mikej71
Unregistered User
mikej71's Avatar
I believe that a 2 bolt 400 has 2 fleeze plugs on the side, and a 4 bolt has 3. I may have that backwards, and I'm too lazy to go out and look at mine. Anyhow, 400s have both 2 and 3, so that's not a good test. Definitely try to see the casting #s.
Mike
71 SWB Stepside
SB400/TH350
mikej71 is offline   Reply With Quote
Old 05-19-2003, 08:27 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Hope for a 2 bolt...the 4 bolt ones were not as strong.
Not all had the extra freeze plugs, many had the bosses for the plugs, but some had no plug, no boss. (like the one I sold Blue)
Old 05-19-2003, 08:45 PM   #7
Blue_71
Bloo
Blue_71's Avatar
hmmm.. ya know horn, that makes it really easy to claim it as a smaller engine if i wanted to trick someone after a race
Old 05-19-2003, 09:29 PM   #8
dinnut
dinnut's Avatar
i noticed the strength factors in my white and blue truck. the white truck engine is a 350 out of a 72 chevelle. even though its a 2 barrell it is a lot louder overall. a lot of difference in a truck and car engine. blue truck has a truck 350. runs a lot different. i can light em up off the line easily on that 2 barrell 350 ( its got a cam bc it lopes - hehe) blue truck engine is alot better running even though the passing gear isnt hooked up.
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 05-19-2003, 10:03 PM   #9
Low69CST
4 bolts have 3 freeze plugs and 2 bolts have 2 freeze plugs. I built a 4 bolt block. I had a 2 bolt block but didn't have the cash for splayed caps. So I stuck with the 4 bolt, I'm not drag racing, so my ocasional heavy foot shouldn't hurt it. I can't remember any other external clues to whether its a 400 or not, Balancer size is only way i know. You could tell the guy to yank off the heads and measure the bore, stock is 4.125. It would be a good idea to check the cylinder walls anyway, if it would have to be bored bigger than .030 I would stay away from it.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 05-19-2003, 10:49 PM   #10
Longhorn Man
Another thing comes to mind, on the sides of the block, where the freeze plugs are, the 400 bulges around each cylinder.
The 2 bolt = 2 freeze plugs and 4 bolt = 3 plugs does not always hold water. I have owned a 400 that was a 4 bolt that had 2 freeze plugs. It was the one that was in my GMC when i bought it.
Old 05-20-2003, 01:21 AM   #11
chevy69er
If your gonna have the heads pulled off check for steam holes on the deck of the block.They are between the cylinders.
1969 C-20,383 stroker,sm465,custom long travel front suspension,4 wheel disc brakes,35" pro comps...mods under way include: 4x4 conversion,and custom bumpers.future mods include: gear vendors od unit,and relocation of fuel cell.
chevy69er is offline   Reply With Quote
Old 05-20-2003, 08:05 AM   #12
Blazer1970
Blazer1970's Avatar
A 400 SB with a 2bbl in a '72 Caprice should have suffix code CKP. If it was a police or taxi application, it could be CDL or CDM. A 4bbl could be CTB.
Blazer1970 is offline   Reply With Quote
Old 05-24-2003, 06:51 AM   #13
mikegi
going on road trip this morning,thanks for the info.motor has 3 freeze plugs and counter weight on balancer.the guy said it ran excellent and did'nt burn oil.we'll see,can't wait.i'll let you all know how i made out.by the way its got a th 350 tranny,will that hook right up to our trucks??
Springvale,Maine
71 3/4 GMC lwb
Old 05-24-2003, 03:29 PM   #14
dinnut
dinnut's Avatar
mostly all auto 350s had th350s behind them.
70 longbed
496/th400/Ford 9"
Old 05-24-2003, 04:40 PM   #15
mikegi
well igot there and it was a 4 bolt 3 freeze plugs,but high miles and noisy.some people think they have something worth of value when they really don't.the motor was really worn.Oh well,thanks for all your input
Springvale,Maine
71 3/4 GMC lwb
Old 05-24-2003, 06:43 PM   #16
Tracy Focht
Tracy Focht's Avatar
so did you get it?
Tracy Focht is offline   Reply With Quote
Old 05-24-2003, 06:53 PM   #17
mikegi
i passed on it
Springvale,Maine
71 3/4 GMC lwb
Old 05-24-2003, 11:44 PM   #18
Longhorn Man
You could get it pretty cheap since it sounds sick, and give it a second life with rings and bearings.
