Old 05-05-2010, 10:22 PM   #1
garage C20
garage C20's Avatar
i lifted my '79 C20... 3 in. fabtech springs and balljoint spacers.
a while a go i was given a set of new in box fabtech HD 3 inch front springs. i held off installing them because they required the use of balljoint spacers... spacers that fabtech had not carried for over 4 years. so the search was on for spacers.... i found some online.. unfortunately the only place was Airbagit.com. so, i bit the bullit and ordered a set ... and ... they worked great. i did have to drill out the balljoint mounting holes a little bit to use the larger diameter bolts that came with the spacers (3/8 in). the hardest part was getting the old riveted ball joints out of the truck. i didn't take all that many pictures of the install but i did get a couple of measurements of before and after.... in total lift i got just over 3 1/4 inches with these springs over the stock 1979 C20 springs. i did notice that i will need a little bit longer front shocks as i had to compress the suspension a bit to get them to bolt back up. but that was before i had it back on the ground. i also noticed that there is more down travel when using the balljointspacers. i took it for a quick spin around the block at it rides fine... the alignment is way out so no more driving untill i get the alignment done.
i am running some smallish tires in the front but i have a set of 33 inch tires on 20 inch wheels that i ran on the truck for a little bit before removing them because they rubbed on the inner fenders. i know i can run them now without any rubbing.
measuring the front from the ground to the front fender opening...
measurement after the spring install......
over all shot..... now it needs to get an alignment... it has major toe in...
'79 C20. Fabtech 3in lift springs in front flipped upper balljoints with spacers (rancho shocks), single 3 in. exhaust (Flowmaster) Edlebrock 1406 carb (600cfm), Edlebrock eps performer manfold, MSD 6a ignition, Empi euro headlight conversion w/Hella 90w/130w H4 bulbs, Hella 500's w/HIDs (all on relays), 20 wheels wrapped in 33in tires.
soon: , 2in blocks and air bags in the rear, headers, dual exhaust, cam/lifters.
garage C20 is offline   Reply With Quote
Old 05-06-2010, 12:38 PM   #2
Matt Man
Matt Man's Avatar
Re: i lifted my '79 C20... 3 in. fabtech springs and balljoint spacers.
looks really good. i wish they just made a leveling kit for these trucks. do they still happen to sell springs and do they have balljoint spacers for a c30?
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 05-06-2010, 02:52 PM   #3
garage C20
garage C20's Avatar
not sure where you could get fabtech springs but the balljoint spacers are at Airbagit.com . the C20 balljoint spacers should fit your C30. i think they sell lift springs and arms on there as well but i do not have any experience with them.
Old 05-06-2010, 03:26 PM   #4
Prerunner1982
Prerunner1982's Avatar
Garage C20... truck looks good.
Matt Man: If you just want to bring the front up a set of 3/4" coil spring spacers should work. Will bring it up a couple of inches and should level it with the back.
My 82 C10 only had HD front coils (1ton or Diesel) and ran 32x11.50s all around with only minor rubbing on the front.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 05-13-2010, 03:53 PM   #5
garage C20
garage C20's Avatar
i got my 33's back on the truck.... plenty of clearance now with the lift on.... next on my to do list is a set of blocks to lift the rear and some longer shocks for the front. it rides firm but nice...
Old 05-13-2010, 04:33 PM   #6
Prerunner1982
Looks good!
Jon
Oklahoma Roll Call
Old 05-13-2010, 04:37 PM   #7
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Sweetness! Thats badarse!
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 05-13-2010, 04:50 PM   #8
3r!c84
Badass
3r!c84's Avatar
nice i like the rims! well the whole look of the truck! id lift of the back alitte tho
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 11-08-2012, 08:49 PM   #9
rmccloye
rmccloye's Avatar
Hey. How much did those coil springs settle? That's if they settled. Thanks.
rmccloye is offline   Reply With Quote
Old 11-08-2012, 11:00 PM   #10
INSIDIOUS '86
INSIDIOUS '86's Avatar
I'm assuming the top ball joint had to be spaced so the upper arm was not at such an angle and the ball joint did not bind?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 12-13-2012, 07:11 PM   #11
sir_talk_alot
sir_talk_alot's Avatar
have you got the blocks on the back yet? id like to see it complete
-Mike-
'94 GMT 400 ext z71 3" body, 3 in rough country, hd mirrors, 20" motometals on 35s
sir_talk_alot is offline   Reply With Quote
Old 12-13-2012, 09:15 PM   #12
INSIDIOUS '86
Could have just got qa1 or Howe balljoints and get bigger balljoints studs to go in. Not sure how reliable a spacer can be
Old 09-20-2013, 12:31 AM   #13
stersam
that thing is awesome. were you able to get the aliment back into shape?
stersam is offline   Reply With Quote
