Old 05-13-2010, 07:46 PM   #1
Mattsch18
Re: 305 heads on a 350?
well lol here you go i just got casting numbers for ya! lol 376450
Mattsch18 is offline   Reply With Quote
Old 05-13-2010, 07:58 PM   #2
USSkoval
I have a set of those, IIRC, they are the ported ones. Apparently there are some roundy round guys that like to run them because they are legal to use in their class. I will be using mine again, but only because I have them, and I'm building a Camaro on the cheap, with parts I have laying around.
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'79 K30 Crew Cab Dually
'84 C10 Short Stepside
'88 K20 Suburban
USSkoval is offline   Reply With Quote
Old 05-13-2010, 10:09 PM   #3
bitchin85
bitchin85's Avatar
did a little research on these.. 60cc chambers.. flow very badly and have tiny valves.. recomended running them on like 93 octane fuel.. with a super high compression ratio engine (depending what pistons you have), its not gonna have much power or rev real high when they flow that bad.. i have the same problem as you.. which is why im gathering parts for a vortec swap
"I'll keep my guns, money, and freedom. You can keep the "change"
bitchin85 is offline   Reply With Quote
