#251 |
Re: 52 GMC Envoy Burb meld/build
amazing build!!
WTB 73-87 SWB fleetside bed!! 85 C10 6.0 project 69 camaro ls1 / t56 90 mustang lx 75 bronco injected 351w
#252 |
Junior Member
The most amazing doors I have ever seen. I just picked up the front clip and doors from the dipshop. They even remarked how nice they are. They look like brand new. Not ONE pinhole of rust in either door, and not even a door ding!!
![]() My 'electrician' will be looking at the truck this evening to determine where the computer and battery will go. Sorry guys, I won't be using the current battery box.
48 GMC Panel Sold 12-14-15 52 White/Chevrolet School Bus 52 GMC Burb/Envoy Meld 61 Impala Wagon SOLD BARRETT JACKSON SCOTTSDALE 1-18-13 67 c/10 SOLD 2012 71 SS454 77 c/20 Sold 11-11-15 08 TBSS The Wife's car!! 50 GMC School Bus SOLD 11-7-10 29 F**D Delivery (Chevy powered) SOLD 11-4-11 53 GMC 630 Firetruck/Ramp Truck |
#253 |
That sucks about the battery box :P
Very nice news on the doors.
My AD Truck Build Thread 52 GMC one day laying on the running boards 2004 Chevy Crewcab. 3/5 and notched |
#254 | |
#255 |
VA72C10
![]() Join Date: Mar 2008
wow, those doors are amazing!
#256 |
Junior Member
Envoy dash cover installed. You can see how much wider it was than the 52. I'll improvise with the side vents and headlight switch. Where it attaches to the dash I will heat the plastic and raise it after we install something under the windshield for support and to attach the window trim to.
#257 | |
The response was underwhelming - mostly the sound of crickets. One guy said he had done one and put the ECM inside the cab on top of the tranny tunnel and he had just cut and spliced his harness one wire at a time. I doubt there is an aftermarket "extension harness" available that would make this easier. On my project I think I will be able to keep the ECM inside the engine bay and just fab/mod the bracket a bit. But if I have to move it far enough that it requires cutting the harness then I am going to aim for under the passenger seat. |
#258 |
![]() Join Date: Jul 2007
Is there room enough to put the ecm in that space to the right of the glove box? I'm not sure how much space you have there but it looks like you could mount the ecm to that bigger bracket and have a removable plate (maybe two) for access.
#259 |
Junior Member
I am taking it tomorrow to a local stereo shop where they will be moving the ECM and the battery. The guy does awesome work and was an electrical engineer for GM. Good creds! He says it will take him less than a day.
We will start fitting the front sheet metal Friday. I think the doors will be on it before I run it to the stereo shop tomorrow.
#260 |
Can you post up a pic of the underhood by the ecm? If its bolted to the intake like my wifes I didnt think clearance would be a prob. Looking good though
I stumbled across this the other day. pretty much the same idea, kinda. http://www.honda-tech.com/showthread.php?t=2763036 Nick |
#261 |
I did the opposite on my Jeep....I took 36" out of all the wires going to the ECM. One good night with my soldering iron and heat shrink and I had it done. One wire at a time, and find a comfortable position to sit in and it's not too bad.
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
#262 | |
Junior Member
(And no, the back door isn't 'taped' on. The tape covers sharp edges on the tin used to strap the door on for fitment.)
#263 |
![]() Join Date: Aug 2005
Now that's
#264 | |
Junior Member
48 GMC Panel Sold 12-14-15 52 White/Chevrolet School Bus 52 GMC Burb/Envoy Meld 61 Impala Wagon SOLD BARRETT JACKSON SCOTTSDALE 1-18-13 67 c/10 SOLD 2012 71 SS454 77 c/20 Sold 11-11-15 08 TBSS The Wife's car!! 50 GMC School Bus SOLD 11-7-10 29 F**D Delivery (Chevy powered) SOLD 11-4-11 53 GMC 630 Firetruck/Ramp Truck Last edited by BBEEP; 05-13-2010 at 05:06 PM. |
#265 |
Junior Member
I know its a little early in the process, but I'm thinkin tail lights . . .
HHR, 2003 Vette, 2000? Cadillac, 1952 Burb, 41-48 Chev pass. car, frenched.
#266 |
1952 Burb,
41-48 Chev pass. car, frenched. Like the Burb best, the frenched would be cool too as they would match your panel. The more I see the HHR the more it grows on me. Loving the build !
"I feel the need for speed!"... as soon as I am done with my nap. Last edited by NONHOG; 05-13-2010 at 06:33 PM. |
#267 |
I think to continue the "old mixed with modern" theme you've got going on, you have to use the HHR tail lights.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
#268 |
A320 Pilot/USAF Retired
Hhr!!!!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 Last edited by ChuckDriver; 05-13-2010 at 08:20 PM. Reason: Grammer |
#269 |
Tripple Five Fanatic
HHR all the way!
Tri5
1955 Chevy Stepside/LS1 drive train http://67-72chevytrucks.com/vboard/s...d.php?t=371513 |
#270 |
Chevy Enthusiast
I like the HHR !
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) Last edited by 1985-GMC; 05-13-2010 at 09:44 PM. |
#271 |
Im diggin the HHR's, I found this and it gave me a chuckle
#272 |
Junior Member
Have been leaning towards the HHR's frenched into the door. The back door will have a pushbutton opener just to the right of the window. I want it to disappear into the darker upper color.
48 GMC Panel Sold 12-14-15 52 White/Chevrolet School Bus 52 GMC Burb/Envoy Meld 61 Impala Wagon SOLD BARRETT JACKSON SCOTTSDALE 1-18-13 67 c/10 SOLD 2012 71 SS454 77 c/20 Sold 11-11-15 08 TBSS The Wife's car!! 50 GMC School Bus SOLD 11-7-10 29 F**D Delivery (Chevy powered) SOLD 11-4-11 53 GMC 630 Firetruck/Ramp Truck Last edited by BBEEP; 05-14-2010 at 12:46 AM. |
#273 |
So wrong. BBEEP I say go with the big stock ones or the HHR look. Are you going to keep the ambulance theme in anyway?
#274 |
I got the small ones like on your yellow for mine. But I like that HHR look.The more I look at your tailgate on your burb the more I like it would they interchange with a 54 panel. I may need to find one
#275 |
Ive been starring at the tail lights on my moms hhr every time I visit. Thinking how much she would mind if it "borrowed" them for my gmc.
| Bookmarks |
| Tags |
| suburban |
